Taurus fan swapping questions (for those who have done it, and ford gurus)
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
At the junkyard today I had a heck of a time looking for the right fan, So I got the one with the closest part number I could find, 8c607-aa. (I think, will look and post for sure when I get off work.)
Now, this fan has a three wire connector on the motor. Most swaps I have seen online have a cable attached to the motor with a 3 pin round connector on the edge of the fan shroud. Did I get a good fan, or did I get one with a lower cfm? Just a different style perhaps? Also, how to wire it? Should it come on low with the stock electric fan, or always be on low and have high come on with the stock fan? Or is this something I'm just going to have to play with to see what she likes best? Thanks in advance for the help!
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod jf irc @ irc.freenode.net #jeepforum |
#2 |
Bumpity bump
The fan I got is a F4DH-8C607-AA. Sound about right?
#3 |
Page 2 already? Man, I figured that this would be getting at least a few replies.
#4 |
Seems at though I got the right fan, but I could not get it to fit. I think my radiator may sit back further than most peoples' do.
#5 |
ok so the fan thats in front of the ac compressor serves the purpose of cooling the motor what does the fan next to it do i have never noticed it turning on,
#6 |
www.midcoastjeep.com
Did it come out of a 3.8? I'm sure you've read Go Jeep's write-up (for those who haven't, it is here: http://go.jeep-xj.info/HowtoTaurusFanInstall1.htm.
I'm sourcing a fan right now to do this, but it will be a while before it happens.
'94 Cherokee Country Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler. Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000. Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops. Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer. Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch. Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE. Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas. Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts. Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle. Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan. |
#7 |
Spent whole past Saturday at the JY around here looking for some options to do the electric fan swap and I would like to point out that there's a lot of Ford models with that same 8C607 number in their electric fans plastic cases. As far as I could see also the fan coming from the 2001 Ford Escort is one of the right ones to this conversion, since the fan motor itself is way bigger than the ones found in models like the some taurus, contour, etc with the same number on them.
HTH
xjpro 01 xj limited ZJ rear disc brakes with working parking brake Electric fan conversion with spal fan controller |
#8 |
Yeah, I posted the number for the one I got, and it did pull right on 30 amps for high, so I'm pretty sure it's the right one. I got it from a 3.0, but from what I could see, it was the same as the 3.8 one.
It was about a half an inch too thick for me.
#9 |
i dont mean to sound stupid but what purpose does th electric fan serve that the metal one doesnt, and when is it suppsed to kick in.
#10 |
The electric fan kicks in when you get too hot at idle, and the steel fan can't keep up. The idea of swapping to an all electric setup is to have less lag on your motor's revs, and to be able to dump maximum cooling power into it whenever you want.
![]() While I was playing with the electric fan, I had to turn the jeep around with no fan on it at all, and it sure does make a difference. The engine felt a lot more peppy without the extra load.
#11 |
Frees up a few horsepower since there isn't the drag on the motor spinning the mechanical fan.
Shawn '00 TJ Sahara (RC 4" LA kit) '06 Grand Cherokee Limited '07 Ram 1500 quad cab Heritage Region Jeep Alliance |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
