Quantcast TassieXJ budget buildup. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > TassieXJ budget buildup.
Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJRUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp Series
Old 05-09-2008, 07:05 AM   #16
Power5
Awesome work on that rear bumper.
Why not cut the metal where the tire mounts? What is the need for the part sticking up past the joint?
Aaron
1999 XJ @ 6” on TSL 35s w/ Aussie D44 & XRC8
Power5 is offline   Reply With Quote
Old 05-10-2008, 05:37 AM   #17
TassieXJ
1995 XJ Cherokee
Im plannig on going to 33" and want the tyre up agaist metal for surport
TassieXJ is offline   Reply With Quote
Old 05-10-2008, 05:47 AM   #18
TassieXJ
1995 XJ Cherokee
Bonnet vents
Ive also put bonnet vents on to drop the temp.
This is what it should look like when finish
Sarted the marking (got from go jeeps site)
The cutting
This is what see looks like
Old 05-10-2008, 06:39 AM   #19
broncofire75
The cutting
Click free. Nice build man.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote
Old 05-10-2008, 02:47 PM   #20
sean883
sean883's Avatar
The rear bumper looks good.
sean883 is offline   Reply With Quote
Old 05-10-2008, 04:32 PM   #21
burger
Those vents look great!! Where did you get them??
burger is offline   Reply With Quote
Old 05-10-2008, 05:43 PM   #22
Mr_Random
1986 XJ Cherokee
Could be something obscure to us, he's in Australia... I'm loving the fab work on the bumper, it looks deceptively beefy, but I didn't see how he mounted it, could be a weak spot there... I'll look again.
I want to do some vents like that, the jeep doesn't overheat, but it's cool looking and will offer much better airflow, can probably make a snorkle out of them too...
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Old 05-10-2008, 05:47 PM   #23
TassieXJ
1995 XJ Cherokee
Thanks for the comment, the vents (brand SAAS) are off ebay (the Australia site) for $30 each.
Old 05-10-2008, 05:59 PM   #24
TassieXJ
1995 XJ Cherokee
Didnt get any good pictures of the mounts.
I cut the hole in the back of the jeep to fit a 50x50 angle (5mm thick) to run thought the chassis.
The mounts also act as the towbar bolt up. The base plate is out of 8mm thick plate and with two 50x50x3mm square tubing the mainbar is welded too.
This one shows there the towball bolts up.
Old 05-11-2008, 03:14 AM   #25
Mr_Random
1986 XJ Cherokee
click free for ya, I'll edit with a response (too lazy to actually click)
haha, wow... doubt those are going anywhere!!!
Jeepus buildicus:
http://www.jeepforum.com/forum/showthread.php?t=757079
Old 09-28-2008, 06:55 AM   #26
TassieXJ
1995 XJ Cherokee
a little update, put 33"s on the little girl.
Moved the flares up around a 1 1/2 inchs. When it stops raining l get some better pictures
Front
Rear
Old 09-28-2008, 07:56 AM   #27
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
good looking jeep, those 33's look much better.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 09-28-2008, 11:25 AM   #28
jeeper01
Nice looking rig... what did you put on the front and rear fenders after the trim?
1998 Cherokee Classic... 2" BB on Moabs
1988 Cherokee Limited... 4.5" RC lift, RK longarms, on 31's. Several homemade skids.
jeeper01 is offline   Reply With Quote
Old 09-28-2008, 12:00 PM   #29
CDX74
nice looking jeep man, your tyre carrier is impressive.
'99 Cherokee Sport 4x4
TnT Long Arms, Rough Country Shackle Relocation Kit, RE coils and leaf springs from 4.5" kit, ORO U-turn steering, AA SYE, 4.56 Superior gears, OME Shocks, Heavy Duty adjustable track bar, NP231, 33" TrXus MT, Hella headlights w/ IPF Fatboys, Monitor Lizard Front Bumper, Hanson read bumper w/ tyre carrier, AirFlow Snorkel, ARB Air Lockers front & rear, Brown Dog engine mounts, Kilby gas tank skid
My CarDomain page
CDX74 is offline   Reply With Quote
Old 09-30-2008, 05:04 AM   #30
TassieXJ
1995 XJ Cherokee
Used flexy flares
Glock Forum
