tailights not working - JeepForum.com
post #1 of 5 Old 03-03-2013, 07:37 PM Thread Starter
BryceBrown
1987 XJ Cherokee
Ok so I have an 87 jeep cherokee and am getting no tail or brake lights and no dashlights the fuse is good it was popping the fuse untill I changed the headlight switch the fuse stopped poping but the taillights or dash lights will not work I also replaced the brakelight switch what else can cause this the bulbs are fine and the wiring does not seem to be burnt up
BryceBrown is offline
post #2 of 5 Old 03-04-2013, 05:24 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
If you have meter you can test for voltage at the tail lights, and work your way up through each connector until you find where it is lost. This is how I usually diagnose any wiring issues.
xjfever is offline
post #3 of 5 Old 06-07-2013, 08:22 AM
RStanger
Had a similar problem, fixed it.
I have a 99 XJ that lost the front running lights, dash illumination, and tail lights.
I checked the two fuses in the fuse panel inside the vehicle (#7 and #23 for the 99 XJ), they were good.
Using my VOM and a wiring diagram, I checked for output voltage (blk/yel wire, I think for the 99) at the H/L switch: 0 volts. Ah-HA!
I replaced the H/L switch with a known good one, no change.
Referring once again to my wiring diagram, I checked for voltage coming INTO to H/L switch for the lights that are out (tan/? wires, for the 99):
0 volts. Hmm...
....back to the wiring diagram. What's ahead of the H/L switch that feeds current through the tan/? wires?
It seems there is a mysterious "fuse #17, 20 amp" before the H/L switch.
Interior fuse box has a #17 fuse, but it is clearly NOT for the dead lights, according to my wiring diagram.
I check the "main" fuse box under the hood. No numbering there just the goofy list inside the lid, and some of the fuses aren't identified at all.
So I checked every 20 amp fuse I saw there, and voila! I found a blown 20 amp fuse!
I replaced it with a spare, and everything is back to normal!
RStanger is offline
post #4 of 5 Old 06-07-2013, 08:56 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I got a headache reading this.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is online now
post #5 of 5 Old 06-07-2013, 08:56 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Got some hacked up trailer wiring plug/harness on it?
