tachometer - JeepForum.com
post #1 of 1 Old 03-24-2011, 04:25 PM Thread Starter
metalman1400
tachometer
OK so i just fixed a vacuum leak. and everything was perfect for a few days. then i noticed my tach on idle was just bearly off the little pin. but the car acts normal like it has a normal idle. i recall a few months ago that the tach messed up for a bit then stopped. i cleaned up the throttle body, butterfly, iac, etc.... no change. is it just the tach and if it is i wont worry bout it much. but if its something else point me in the right direction to get it taken care of.
metalman1400 is offline
idle , idle issue , tachometer
How do you add a ?? tachometer ?? 1984XJ XJ Cherokee Technical Forum 2 07-07-2009 11:12 PM
tachometer Delox XJ Cherokee Technical Forum 3 11-02-2007 01:30 PM
New Tachometer chocflip201 XJ Cherokee Technical Forum 1 06-17-2007 05:53 PM
tachometer xj BMX xj XJ Cherokee Technical Forum 1 11-19-2006 09:21 PM
tachometer xjinthemud XJ Cherokee Technical Forum 3 10-15-2003 05:23 PM
