Tach wire - JeepForum.com
post #1 of 9 Old 12-31-2013, 01:26 PM Thread Starter
Project1
Tach wire
Does anyone know where the tac wire is. I think it comes off the distributor but I'm not sure what wire it is. Any help would be awesome
Project1 is offline
post #2 of 9 Old 12-31-2013, 02:59 PM
green97xjsport
1997 XJ Cherokee
Not sure on the 98, I know for older ones, you can pick up the signal from the black wire I think from the coil if you're talking about an aftermarket coil, I know the factory tach coverts it signal from the power control module. Not familiar with the 98, does it have a single coil, or multiple coil packs?
I'm sure a 98 owner will chime in.
,======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
green97xjsport is offline
post #3 of 9 Old 01-02-2014, 10:35 AM
madmax85
1989 MJ Comanche
I believe the tach wire for the gauge actually comes from pcm/ecu. If you are running an aftermarket tach you could splice into the negative on the coil
madmax85 is offline
post #4 of 9 Old 01-02-2014, 01:05 PM
holysirsalad
+1 at least on OBD-II, the dash uses the signal from the CPS.
holysirsalad is offline
post #5 of 9 Old 01-02-2014, 08:49 PM
sAe23
1995 XJ Cherokee
I was wondering about this for my 95 (ODB1)... Where does the ECU get its signal? I glanced through the FSM but didn't find anything (not sayin it wasn't there, just...)
sAe23 is offline
post #6 of 9 Old 01-02-2014, 09:11 PM
holysirsalad
From the CPS
post #7 of 9 Old 01-03-2014, 07:01 PM
madmax85
1989 MJ Comanche
what are you needing to know for? i put megasquirt on my comanche and when i hooked the factory tach up to the coil negative it reads 1.5 times the actual rpm. so in a basic sense the computer sends a 4 cylinder signal to the gauge cluster for the tach. its really weird.
madmax85 is offline
post #8 of 9 Old 01-04-2014, 01:52 AM
sAe23
1995 XJ Cherokee
If you are asking ME, I was just curious. I had two isolated instances of a momentarily dead tach and started to wonder about how it all worked...
sAe23 is offline
post #9 of 9 Old 01-04-2014, 11:01 AM
madmax85
1989 MJ Comanche
i gotya, glad to help, and just some fyi info for ya
madmax85 is offline
