T and T Subframe Stiffeners - JeepForum.com
post #1 of 4 Old 05-17-2013, 01:51 PM Thread Starter
Newtons3
Newtons3's Avatar
Anyone running T and T Subframe connectors? Living in south Louisiana, my concern is that water, mud, etc is going to get between the subframe and the stiffener and rot out the frame. What did you do to stop this?
Newtons3 is offline
post #2 of 4 Old 05-18-2013, 06:11 PM
RockRodHooligan
RockRodHooligan's Avatar
Ran them on my 01 XJ, made a huge difference in the way it handled. You will have to strip the factory rails down to bare metal. I've used this while building the bed on my MJ, and it works pretty good. Spray both the frame rails and the inside of the stiffeners before you put everything in place and start welding.
My only complant with the TNT stiffeners was it was really hard to get the welder into a good position to weld the outer edge right. I ended up spending a couple hours drilling a bunch of holes in them for plug welds to get a little better hold. If I had to do it again(and I will be on my 96) I'd go for the HD Offroad stiffeners. They are a little thinner(10gage/ just a little more than 1/8"), but they are cheaper and already have the holes for plug welds(allbeit a cubic butt ton).
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #3 of 4 Old 05-18-2013, 08:35 PM Thread Starter
Newtons3
Newtons3's Avatar
Thanks for the reply. This has been an ongoing debate. I am capable of welding these but I have whole bunch of people more skilled than I willing to help. They are advising against these weld through coatings even though that's what everyone who has run them says to do. I'm probably gonna just use something like this and go ahead and do it.
Newtons3 is offline
post #4 of 4 Old 05-18-2013, 08:44 PM Thread Starter
Newtons3
Newtons3's Avatar
Well, I just looked up the HD Offroad stiffeners. I think you're right. I think I'm going with their full set. Thanks.
Newtons3 is offline
