Symptoms of a bad TPS? - JeepForum.com
post #1 of 5 Old 09-28-2013, 10:02 AM Thread Starter
Jeepnbo
Heres the deal. 99 4.0 auto. Once i first fire it up and drive somewhere its fine but if i park, shut it off, and go to leave again, it bogs down and suddenly clears up and is fine. TPS??
Jeepnbo is offline
post #2 of 5 Old 09-28-2013, 12:09 PM
SaarXJ
It might be the TPS, but I believe it is not.
I would start with cleaning the IAC.
Bad injectors may cause tough starting while the engine is hot as well.
2001 Jeep XJ
1988 Alfa Spider
2001 Mitsubishi Montero
Now, Jeep Grand Cherokee WJ 2000.
SaarXJ is offline
post #3 of 5 Old 09-28-2013, 12:15 PM
psychoteen101
Check your fuel pressure when the bog occurs. Check engine light on? Even if its not, see if any codes are stored. Might have a code pending if this started recently
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #4 of 5 Old 09-28-2013, 06:54 PM Thread Starter
Jeepnbo
No cel that i know of. Last time i had the code ran it was PO705 trans range sensor circuit?? I'll look into cleaning the IAC
Jeepnbo is offline
post #5 of 5 Old 10-01-2013, 08:06 AM
robtco99
The TPS also controls trans shifts. When mine went bad the trans would shift kind of hard. As soon as I replaced it the trans shifted smooth.
2001 amber fire cherokee sport 4x4, 2 in lift, 30x9.50 generals, 174 ion wheels, pretty much stock.
robtco99 is offline
