symptoms of bad fuel pump - JeepForum.com
post #1 of 7 Old 07-08-2007, 12:15 AM Thread Starter
ar275103
1993 XJ Cherokee
I have a 93 cherokee and think my fuel pump may be going bad. Will they start to go out before they actually quit working? What symptoms are experienced when a fuel pump is going out or is bad? Besides the fuel pump is there anything else that may cause a cherokee to loose power and stall?
ar275103 is offline
post #2 of 7 Old 07-08-2007, 02:40 AM
NinjaofDoom
1990 XJ Cherokee
fuel filter, bad sensors(cps, o2, etc) fuels pumps from my experiance tend to shut off your car then work fine later then die again. check it have pressure at the rail if it dies.
There was the episode where I threw my shoe at the enemy, like this!.... my foots cold.
NinjaofDoom is offline
post #3 of 7 Old 07-08-2007, 02:45 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Check your catalytic convertor.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 7 Old 07-08-2007, 11:19 AM
severous01
severous01's Avatar
you got no power, hesitation? check air filter, fuel pressure, fuel filter, timing, pull ox sensor and see if that helps (if so you need exhaust), throttle position sensor, throttle for goop and gunk, IAT sensor for open/closing.
fuel pumps usually dont slow down, they just stop....and most likely when you need it the most, like on the way to that new job interview or when you need to get the wife to the hospital because she's in labor....something like that.
i need more than just what you've explained. i need rpm, load % (assuming you're not talking WOT), maintenance recently done, what gas you buy (e85 or regular, addatives used...that kind of stuff.)
severous01 is offline
post #5 of 7 Old 07-08-2007, 01:48 PM
jimmmy
The fuel pump in my '88 started making a whining noise before it gave out.
jimmmy is offline
post #6 of 7 Old 07-08-2007, 09:58 PM
GearGuy10
X2 on the whining noise. After installing 3 fuel pumps in the last 11 months, I am now very attuned to the noise it makes when it energizes when turning the key. It should be a short low hum. Mine started an irregular higher pitched buzz before it just went.
HIS: 1998 Cherokee Sport Chili Pepper Red-SOLD
DrawTite front hitch
HERS: 2009 Liberty Sport Light Graystone Pearl
100% Stock
GearGuy10 is offline
post #7 of 7 Old 07-08-2007, 09:59 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
Mine buzzed so I put a new one in. Still buzzes. Whateva.
Factory Four Link
XJLI is offline
Fuel pump relay clicks, pump doesn't run RogerRoger XJ Cherokee Technical Forum 9 07-19-2015 11:41 AM
88 4.0 auto fuel pump always runs.. regulator or pump? robdoggydog1 XJ Cherokee Technical Forum 11 01-29-2010 07:33 PM
How to test: fuel pump relay or pump itself? tombob XJ Cherokee Technical Forum 0 11-11-2007 10:53 AM
fuel pump failure symptoms? motu1983 XJ Cherokee Technical Forum 3 10-19-2007 01:53 PM
Fuel tank lowering tips, and Ebay fuel pump/filter Q's cmassey_2006 XJ Cherokee Technical Forum 10 03-14-2007 06:16 PM
