SYE on...still got the vibes! - JeepForum.com
post #1 of 30 Old 10-13-2008, 09:54 AM Thread Starter
Eggdashure
Hey all,
Ok, I finally got some time to roll under my Cherokee and get down to installing my RE HnT. Just some specs 99 Cherokee, 4.0L, NV242, 8.25 in the rear with a 4 degree shim. I set everything up so that I could use the driveshaft off the front of another XJ.
So I got it all bolted up, and couldn't wait to go for a test drive. Driving around in FWD was getting old, too much babying. I could tell immediately that things were better, with the stock DS I had vibes starting at 15MPH. But when I hit 35MPH I couldn't feel any vibrations, but I could hear them. Does that make any sense? Also, I noticed that when I let off of the accelerator, the vibrations went away, as soon as I gave in some juice they were back.
Any help appreciated.
Matt
Eggdashure is offline
post #2 of 30 Old 10-13-2008, 10:08 AM
peleejosh
How are the ujoints on the driveshaft that you used?
Originally Posted by Eggdashure View Post
Hey all,
Matt
peleejosh is offline
post #3 of 30 Old 10-13-2008, 10:58 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
How much lift are you running? "home brew" doesn't tell us how tall it is.
Check to make sure there's no slop in the yoke on the "new" rear driveshaft.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #4 of 30 Old 10-13-2008, 11:01 AM
sjbond67
maybe too much shim?
sjbond67 is offline
post #5 of 30 Old 10-13-2008, 11:02 AM
bikedude189
1993 XJ Cherokee
yeah, check all u joints and pinion angles...
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
post #6 of 30 Old 10-13-2008, 11:13 AM
champelite210
Was your drive shaft shortend by a driveline shop or in the back yard. Possible it didn't get welded on straight.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #7 of 30 Old 10-13-2008, 11:40 AM
peleejosh
When did he say that he shortened the driveshaft?
post #8 of 30 Old 10-13-2008, 12:52 PM Thread Starter
Eggdashure
U-Joints: Brand new on what is now the rear of the shaft. In the Cardan, they weren't that old so I re-used them. I was told only about 10K on the joints.
The shaft: Remains at stock length, according to this post, I didn't need to mess with it.
Lift: If I'm measuring properly (center of the hub to the bottom of the fender) I'm sitting at 21" front and back or about 3.5 up front 4 in the rear.
Thanks!
post #9 of 30 Old 10-14-2008, 09:30 AM Thread Starter
Eggdashure
Any ideas guys? So far looks like 2 votes U-joints. 1 vote, shims/pinion angle.
Thanks!
post #10 of 30 Old 10-14-2008, 12:26 PM
Highway 4x4
Remove your front DS and check for vibes again.
Highway 4x4 is offline
post #11 of 30 Old 10-14-2008, 01:02 PM
Redrum8675
1978 CJ5
when u take ur front DS out and there are no vibes....wat could be causing it then?....bad u-joint?...cause thats wat happening to me
Redrum8675 is offline
post #12 of 30 Old 10-14-2008, 01:11 PM
Vendor
1995 XJ Cherokee
More than likely, in my experience anyway, that means the yoke and/or splines on the driveshaft slipyoke is worn out. Grab the yoke with your hand and see if you can wiggle side to side relative to the rest of the driveshaft (this is easier to do and see with the shaft installed on the vehicle). If this is the case, you can try replacing just the yoke, but my guess is the whole driveshaft will need to be replaced due to the splines being worn. Though I guess you could also price out having a driveline shop cut off the old slipyoke assembly and weld on a new one.
Also, the word "what" has an "h" in it. Unles ur txtng frm ur fon, or missing fingrz, or r a Chick-fil-A cow, thrz no rzn to mspel wrds... when typing on a full QWERTY keyboard. I can't imagine the hell English teachers in schools must be going through nowadays... Do they even still teach typing in jr high/middle school?
Jason West -
post #13 of 30 Old 10-14-2008, 01:33 PM
100dollarbill
1993 XJ Cherokee
Go get 'em Jason!!! It's hard enough figuring out what peolpe are saying when they CAN spell!
There should be some kind of test you have to take before you are allowed to post. Mods??? Anyone???
Originally Posted by Muddeprived View Post
I also have this strange jerk at the steering wheel
Originally Posted by JLC08JK View Post
P.S. please stop bringing up the CAI, Those Government Guys make me nervous!!!
'93 XJ 4 1/2" lift on 33's
'08 JK Unlimited Detonator Yellow DD
'11 Liberty Sport (the wife's)
100dollarbill is offline
post #14 of 30 Old 10-14-2008, 02:20 PM
TheNerd
TheNerd's Avatar
This is my vote...
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #15 of 30 Old 10-14-2008, 02:25 PM Thread Starter
Eggdashure
Hookt en Fonix Werk'd fer mi!!!
So pull the rear shaft off again and see if it vibes now? Do I pull my whole RE assembly as well?
Something I noticed that makes me believe more in the pinion angle. I loaded the rear of my Jeep with two heavy duty copiers (work stuff ) and drove them back to the office. The vibrations seemed less pronounced with the added weight.
Odd Vibes... bikedude189 XJ Cherokee Technical Forum 2 11-12-2007 05:17 PM
Rear vibes are gone...now the front vibes are back! skenzer XJ Cherokee Technical Forum 13 08-19-2007 04:58 PM
Vibes (not DW) 00xj54 XJ Cherokee Technical Forum 9 12-09-2006 04:27 AM
Vibes? whitexj05 XJ Cherokee Technical Forum 6 03-08-2005 03:38 PM
vibes? whitexj05 XJ Cherokee Technical Forum 1 12-21-2004 09:10 PM
