SYE with the NV 242 Transfer case. - JeepForum.com
post #1 of 15 Old 08-19-2008, 11:09 PM Thread Starter
4X4XJJeep
Can the RE SYE be used with the NV 242 TC. I will more than likely be ordering a custom drive shaft instead of the popular smaller front drive shaft conversion.
Help?
4X4XJJeep is offline
post #2 of 15 Old 08-19-2008, 11:10 PM
the_weirdo
the_weirdo's Avatar
With a 242 you are pretty much limited to the Hack and Tap. It has worked great for me so far.
the_weirdo is offline
post #3 of 15 Old 08-20-2008, 01:32 AM
sprintagogo
The RE 1807 adaptor is intended just for your set-up. Your later nv/np242 has the internal oil seal so it is a really easy install. Why don't you want to use a front driveshaft for the back?
Provided you have the auto tranny the length is spot on for your intended lift, it is miles cheaper than a custom job and I have NEVER heard of one breaking in this application.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #4 of 15 Old 08-20-2008, 09:51 AM
eflores
1989 XJ Cherokee
does any one have a pic of the entire content of the 242 kit?
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline
post #5 of 15 Old 08-20-2008, 09:55 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
You also get some bolts, a washer, drill bit, and a tap.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #6 of 15 Old 08-20-2008, 09:59 AM
eflores
1989 XJ Cherokee
so where d you get the youke to attach your DS to that
AEKDB
eflores is offline
post #7 of 15 Old 08-20-2008, 10:05 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
you use a flange adapter.
you can also get a full SYE kit from Currie and Tom Woods. It'll cost ya, but IMHO worth it.
Factory Four Link
XJLI is offline
post #8 of 15 Old 08-20-2008, 10:08 AM
Vendor
1995 XJ Cherokee
http://www.jeepforum.com/forum/showt...dapter+hack%2A
It's my understanding that both those kits are nothing more than a hack-n-tap kit that they've already hacked and tapped for you?
Jason West -
post #9 of 15 Old 08-20-2008, 10:09 AM
chainerx
Just wondering, but what are the steps to a front drive shaft conversion? I know you need an SYE, and a front drive shaft, but do you need to do anything other than lengthen the front shaft?
chainerx is offline
post #10 of 15 Old 08-20-2008, 10:11 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
Im not sure on the currie kit since ive yet to inquire about it bc i dont have the money for it yet
the TW kit's mainshaft is machined down so you dont have that lip left when you HnT- and yea its a modified stock shaft. the 242 shaft though is stronger than the stock 231 IIRC, and has a 32 spline front output.
Factory Four Link
XJLI is offline
post #11 of 15 Old 08-20-2008, 10:51 AM
Vendor
1995 XJ Cherokee
You shouldn't have to have the shaft lengthened, that's part of the whole point in using a used front driveshaft vs buying a new one.
As far as what else you need, it depends on if you do a hack-n-tap or a heavy-duty SYE. With a heavy-duty SYE, a front XJ shaft just bolts right up to it. With the hack-n-tap you've got to get an adapter flange (read link I posted above) and rebuild the double-cardan joint to replace the existing yoke adapter with the flange adapter.
Jason West -
post #12 of 15 Old 08-20-2008, 11:27 PM
1995sport
1995 XJ Cherokee
I think I remember reading somewhere that the flange adapter was an OEM piece? does anyone have that information? what vehicles, years it was originally used on?
Thanks.
1995sport is offline
post #13 of 15 Old 08-24-2008, 11:26 AM Thread Starter
4X4XJJeep
post #14 of 15 Old 09-02-2008, 05:11 PM Thread Starter
4X4XJJeep
What about the double cardian joint where do you get that?
"What I've want is what I've not got What I need is all around me" DMB
post #15 of 15 Old 09-02-2008, 05:23 PM
Steamer98
Steamer98's Avatar
Its on a front shaft. A front shaft has 3 Ujoints. 2 at the Tcase, and one at the axle pinion/yoke. the 2 U joint configuration on one end of the shaft is called a double carden, somewhat like a CV(constant velocity) joint (but not really).
98 XJ Limited
Stock XJ tire carrier for sale
Steamer98 is offline
NP 231 transfer case............. Maybe XJ Cherokee Technical Forum 8 04-15-2009 07:38 PM
Which transfer case do I have? crna2011 XJ Cherokee Technical Forum 5 03-07-2009 10:31 AM
What transfer case do you have? sharpie XJ Cherokee Technical Forum 14 01-21-2007 11:11 PM
transfer case blackwaterjeep XJ Cherokee Technical Forum 5 01-18-2007 01:14 PM
NP 231 Vs 242 transfer case jeepsurfgirls XJ Cherokee Technical Forum 16 04-03-2006 03:39 PM
