SYE kit and rear shims - Page 2 - JeepForum.com
post #16 of 17 Old 02-14-2010, 06:53 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Rubicon Express RE1469 - Rubicon Express Solid Steel Shims for 2.5" Wide Leaf Springs - Quadratec Many places sell them, this is just one example. The shims aren't welded in, they are bolted to the leafpack with the centerpin. Jeffro was saying that you could have the spring perches cut off, then rotate the axle to the proper angle and have them welded back on. This would eliminate the need for the shims.
xjfever is offline
post #17 of 17 Old 02-14-2010, 07:09 PM
MC_wk
2007 WK
Originally Posted by Jeffro95 View Post
Here's what a SYE / CV driveline needs to look like:
Notice how the pinion angle is rotated up?
I've always wondered how shims are supposed to work when in concert with SYE/CV.
Originally Posted by whiteys_red_XJ View Post
Hey thanks again xjfever and and jeff really aprciated I just want to make sure I now about everything I need to for this size lift this is my first lift I will be ever doing on my first jeep thanks so much for your time guys
Please. Use. Punctuation.
Makes it WAY easier to to understand what you're saying.
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
MC_wk is offline
96 xj , automatic np-242 t-case , rear axle shims , sye kit
shims for rear leafs bokey XJ Cherokee Technical Forum 6 12-16-2007 05:55 PM
Shims for rear XJMudder XJ Cherokee Technical Forum 5 04-24-2007 06:46 PM
Shims in rear axle question Altec88 XJ Cherokee Technical Forum 10 07-16-2006 02:40 AM
Rear degree shims?? X to the J XJ Cherokee Technical Forum 4 11-04-2005 02:44 PM
Rear blocks... do i need shims? 4x4life XJ Cherokee Technical Forum 3 09-09-2005 07:55 AM
