SYE kit and rear shims - JeepForum.com
post #1 of 17 Old 02-14-2010, 08:37 AM Thread Starter
whiteys_red_XJ
Hi if I get a SYE kit after a 4.5 inch lift on 96 xj auto np 242 T-case do I need to have to get the rear axle shims?
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 17 Old 02-14-2010, 08:43 AM
Lupitaboy
Shims work in conjunction with a TC drop in manipulating the rear drive shaft by rotating the pinion angle. An SYE properly manipulates it(proper driveshaft angle) on its own. One last thing...your cherokee is not an FSJ. That designation is reserved for the older, larger waggoneer. If this is wrong, please chime in with a correction.
96 w/ 5spd, 4.10s w/ lsd, Bastard Packs, armor/ rack, BFGs & JK Blacks
Lupitaboy is offline
post #3 of 17 Old 02-14-2010, 08:50 AM
Jeffro06
Jeffro06's Avatar
Originally Posted by Lupitaboy View Post
An SYE properly manipulates it on its own.
No it doesn't. The SYE comes out of the transfer case at the same angle as the slip yoke. The rear pinion angle needs to be changed so the pinion points at the slip yoke output shaft, as opposed to being parallel with the slip yoke output shaft.
In order to get the pinion yoke, of a leaf sprung rear end, to point at the out put shaft you'll need shims or the better method would be to remove the spring perches and have them welded back on at the correct angle.
Of course once you get a SYE you'll need a CV driveshaft.
Jeffro06 is offline
post #4 of 17 Old 02-14-2010, 08:55 AM
Lupitaboy
But would those shims be needed on a 4.5 inch lift? Larger for sure, but...
post #5 of 17 Old 02-14-2010, 08:58 AM
Jeffro06
Jeffro06's Avatar
My YJ has a 4" lift, and I use 8 degree shims. The pinion has to be rotated up to point at the output shaft, no matter what, when using a SYE / CV combo, so it's either shims, or cut off perches and re-weld.
Jeffro06 is offline
post #6 of 17 Old 02-14-2010, 08:59 AM Thread Starter
whiteys_red_XJ
Hey Lupta thanks I new I have the reg. XJ I just clicked the wrong one when seting up my account just never caught that. And so I DONT need the shims is that what you guys are saying?
post #7 of 17 Old 02-14-2010, 09:00 AM
Jeffro06
Jeffro06's Avatar
That's not what I'm saying.
Jeffro06 is offline
post #8 of 17 Old 02-14-2010, 09:04 AM
Jeffro06
Jeffro06's Avatar
Here's what a SYE / CV driveline needs to look like:
Notice how the pinion angle is rotated up?
Jeffro06 is offline
post #9 of 17 Old 02-14-2010, 09:06 AM Thread Starter
whiteys_red_XJ
Ok so I do need the shimes and do the shines go under the rear leafs?
post #10 of 17 Old 02-14-2010, 09:11 AM
Jeffro06
Jeffro06's Avatar
Ok so I do need the shimes and do the shims go under the rear leafs?
Shims sit on top of the leaf pack, between the leafs and the perch. (spring under anyway)
Jeffro06 is offline
post #11 of 17 Old 02-14-2010, 09:19 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The shims go under the leafs on a cherokee. The YJ is spring under axle, the XJ is spring over axle. And with 4.5" lift 4* shims should get you in the right range.
xjfever is offline
post #12 of 17 Old 02-14-2010, 09:20 AM Thread Starter
whiteys_red_XJ
Ok I think I get it now but I don't think I will have them welded because I don't know how to weld so I'm prob just going to throw them in like reg. And so no matter what I will need the shimes and the SYE kit and what size degree shimes do I need on my xj after a 4.5 in lift?
post #13 of 17 Old 02-14-2010, 09:25 AM Thread Starter
whiteys_red_XJ
Hey thanks again xjfever and and jeff really aprciated I just want to make sure I now about everything I need to for this size lift this is my first lift I will be ever doing on my first jeep thanks so much for your time guys
post #14 of 17 Old 02-14-2010, 09:28 AM
Jeffro06
Jeffro06's Avatar
It's been awhile since I had my XJ....I honestly couldn't remember if it was over or under....
I was originally told 4* shims would work for me too....but they didn't. They might work, but don't be surprised if they don't. Jeeps are funny that way.
Jeffro06 is offline
post #15 of 17 Old 02-14-2010, 05:24 PM
markcrain
Who all sells shims?
markcrain is offline
96 xj , automatic np-242 t-case , rear axle shims , sye kit
shims for rear leafs bokey XJ Cherokee Technical Forum 6 12-16-2007 05:55 PM
Shims for rear XJMudder XJ Cherokee Technical Forum 5 04-24-2007 06:46 PM
Shims in rear axle question Altec88 XJ Cherokee Technical Forum 10 07-16-2006 02:40 AM
Rear degree shims?? X to the J XJ Cherokee Technical Forum 4 11-04-2005 02:44 PM
Rear blocks... do i need shims? 4x4life XJ Cherokee Technical Forum 3 09-09-2005 07:55 AM
