SYE driveshaft? - JeepForum.com
post #1 of 7 Old 11-20-2012, 09:41 PM Thread Starter
93XJproject
1993 XJ Cherokee
SYE driveshaft?
Hey everybody! I have a 93 2dr XJ, I'm adding 4.5" of lift, I'm about to install a rugged ridge SYE, where is the best place to order a new rear driveshaft for this? Also the cheaper the better! Thanks!
93XJproject is offline
post #2 of 7 Old 11-21-2012, 12:41 AM
GetLifted
Pull a XJ front driveshaft and take it to a reputable local driveline shop.
GetLifted is offline
post #3 of 7 Old 11-21-2012, 06:45 AM
JTM1
1988 XJ Cherokee
Cheapest option is getting a front drive shaft from a junk yard and having a machine shop or a driveline shop make it shorter or long as necessary.
If you want the most dependable, Tom Woods.
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
post #4 of 7 Old 11-21-2012, 10:16 AM
GetLifted
BA! FORGET TOM WOODS
From him I got: the wrong length, bad u joints, and a bad centering ball on the Cardan.
Tom woods takes used front driveshafts and re tubes and balances them. Doesn't even replace all the parts. YOU can do better.
post #5 of 7 Old 11-21-2012, 10:54 AM
Kevin108
I'm with GetLifted. Take some measurements first though. If an XJ front shaft is too short, try a ZJ front shaft as it's longer.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #6 of 7 Old 11-22-2012, 11:28 AM Thread Starter
93XJproject
1993 XJ Cherokee
Hey that's awesome thanks everyone!
post #7 of 7 Old 11-22-2012, 07:50 PM
Kevin108
Just FYI, I paid $30 for the last one I pulled.
Kevin108 is offline
