SYE - JeepForum.com
post #1 of 7 Old 03-30-2002, 05:26 PM Thread Starter
BLK2000XJ
Question SYE
I need some input on sye's. Do you use the existing driveshaft? What brand and how hard is installation? I'm getting vibes so I want to do it soon. Thanx
Black, 2000 XJ, Rusty's 3" lift, Heavy Duty SYE, Flowmaster exhaust & 31x10.50-15 BF Goodrich Mud Terrain KM's. So far...........
2003 Liberty Limited, 255/70-16 Goodyear Wrangler MTRs
BLK2000XJ is offline
post #2 of 7 Old 03-31-2002, 07:18 PM
TJs96XJ
Thumbs up
I found one place here that i like is tom woods drive shafts and sye's. here's the link <a href="http://www.4xshaft.com/" target="_blank">http://www.4xshaft.com/</a>
"80" CJ7 Just sitting right now my son will be old enough soon to help with his jeep
"87" Cherokee
"89" Cherokee Mud-dog
"96" Cherokee Country 3.5 RE Lift IT REALLY IS A JEEP THING!!!!!!! $3,100 wish list down from $4,600 God made earth in 6 days and went WHEELINNG on the 7th
TJs96XJ is offline
post #3 of 7 Old 03-31-2002, 08:12 PM
EricsXJ
The Post man
EricsXJ's Avatar
Post
There are several kits (like Tom Woods) that require splitting the transfer case and replacing the stock output shaft with a shorter one. Another option is the cut and tap (aka "hack n tap") kit from RE which I have installed. It is significantly cheeper than the others especially for newer XJs like our 2000s at only about $90. This kit requires you to cut the existing output shaft, drill a hole (bit supplied), and tap threads into it (tap supplied). Then you bolt on the new flange and you will need a CV driveshaft. I chose this kit because I wasn't comfortable with splitting the transfer case and the cost savings were nice. The installation was pretty easy and I have no driveline vibes to speak of. As far as strength is concerned, other kits may possibly be stronger but I have never heard anyone with a firsthand experience of the RE kit failing. There is a good installation write up which I followed at ILOVEJEEPS.com. You can email me or reply here if you have any specific questions about this kit.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 7 Old 03-31-2002, 09:21 PM
BIGNUTT
BIGNUTT's Avatar
Post
DO IT RIGHT! JB Conversions HD SYE $235 and Tom Woods driveshaft.
CANCER AND LUEKEMIA SUCK
Proud to be a Christian
BIGNUTT is offline
post #5 of 7 Old 03-31-2002, 09:25 PM
BIGNUTT
BIGNUTT's Avatar
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by EricsXJ:
<strong>There are several kits (like Tom Woods) that require splitting the transfer case and replacing the stock output shaft with a shorter one. Another option is the cut and tap (aka "hack n tap") kit from RE which I have installed. It is significantly cheeper than the others especially for newer XJs like our 2000s at only about $90. This kit requires you to cut the existing output shaft, drill a hole (bit supplied), and tap threads into it (tap supplied). Then you bolt on the new flange and you will need a CV driveshaft. I chose this kit because I wasn't comfortable with splitting the transfer case and the cost savings were nice. The installation was pretty easy and I have no driveline vibes to speak of. As far as strength is concerned, other kits may possibly be stronger but I have never heard anyone with a firsthand experience of the RE kit failing. There is a good installation write up which I followed at ILOVEJEEPS.com. You can email me or reply here if you have any specific questions about this kit.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">You can probably find someone to help you with the SYE. I have a few friends who are going to help me do it. Thats the great thing about Jeeps, other Jeepers are always willing to help.
I wouldn't trust the el cheapo RE "kit". Take your time and do it the right way. Remember it may cost more now, but it will save you alot of $$$ later on.
BIGNUTT is offline
post #6 of 7 Old 04-01-2002, 05:27 PM Thread Starter
BLK2000XJ
Thumbs up
Thank you for the input guys, it will definitly help. I don't know which way I'm going to go, but now I know what areas to research.
post #7 of 7 Old 04-01-2002, 05:57 PM
CB89XJ
Post
You will be fine w/ the "hack and tap" kit as long as you do it right. A guy in my club has this kit on his TJ w/ 38's and wheels it HARD w/ no problems.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
