I have ABS and need to replace my D35. For the time being, Im just using another D35. However, the new axle wasnt for ABS. How would I switch ABS over to the new axle if its possible?
The tone rings are on the axle shafts so you will need to swap them in and probably the back plates will need swapping at the same time to acommadate the sensors. It should be that simple but I could be wrong?
Your right.. tone rings or axle shafts need to be swapped over along with the backing plate if the existing one doesn't have a hole for the sensor. You may need to take the whole brake assembly over if it has different sized drums.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
