Quantcast Swing Away Tire Carrier - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Swing Away Tire Carrier
Old 04-11-2005, 07:40 AM   #1
SHOCKA
What year model jeeps came with stock swing away carriers. I am going to try to find one in a yard to mount on my 98 cherokee and need to know. Also would it support a 33 x 12.50.
I need to have a spare and dont want to carry it on my roof. The woods are to thick here.
Thanks,
Matt
SHOCKA is offline   Reply With Quote
Old 04-11-2005, 09:15 AM   #2
mrmudder4x4
None, all are dealer installed or aftermarket.
Daniel
Daniel aka Bootlegger of JonFund.com offroad club
People who live in grass houses shouldn't get stoned
http://www.jonfund.com/
mrmudder4x4 is offline   Reply With Quote
Old 04-11-2005, 09:18 AM   #3
XJ-NoDough
I found one at a junkyard. And I was thinking like you "Hey I'd like to mount my spare that way.", but it was pinched between two cherokees so I couldn't get a good look at it. I probably go back out there in a couple weeks.
[SIZE=2][B][COLOR=Blue][B]My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded[/B][/COLOR]
[COLOR=Red][B]4L Selec-trac[/B][/COLOR]
[COLOR=White][B]Automatic[/B][/COLOR]
[COLOR=Red][B]3"-4.5"ish Homebrew lift[/B][/COLOR]
[COLOR=White][B]16x8 MB Motoring Rockers[/B][/COLOR]
[COLOR=Red][B]265/75R16(31[SIZE="1"]ish[/SIZE]"X10.4") Goodyear Wrangler M/TRs[/B][/COLOR]
[COLOR=White][B]Trimmed w/ Bushwackers[/B][/COLOR]
[COLOR=Red][B]Stock 3:55 gears[/B][/COLOR][/B][/SIZE]
[B][COLOR=White]sans big audio[/COLOR][/B]
[B][COLOR=Red]Homebrew intake w/cone filter[/COLOR][/B]
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline   Reply With Quote
Old 04-11-2005, 12:52 PM   #4
cmotsvt
Roof mount. Ive never seen a jeep on or off the road with that rear tire carrier.
cmotsvt is offline   Reply With Quote
Old 04-11-2005, 12:56 PM   #5
jbowser12
balloo has one....
i pm'd him a while back about it...i think he said it was off an xj from europe or something
edit: oh yeah and there is no way this one could hold a 33..he was saying his 31's are the biggest he would think about putting on there
2000 XJ 4.0
Dana LP30/Chrysler 8.25, AW4, NP231
jbowser12 is offline   Reply With Quote
Old 04-11-2005, 12:59 PM   #6
agent9
They DID have one as an OEM option. The one I saw you would have to drill holes as it mounts to the rear right side of the XJ if you find a used one. I guess they did all that at the dealer. I saw one on ebay a couple weeks ago. I have seen one like the picture one ebay recently too.
I picked up an aftermarket one for my 96 off ebay recently that mounts behind the tail lights.
They can be found but be prepared to do some drilling.
BTW, the one in the picture is not the OEM one I saw. ????? I have seen those before though but didnt think it was OEM.
agent9 is offline   Reply With Quote
Old 04-11-2005, 01:02 PM   #7
jbowser12
Originally Posted by agent9
BTW, the one in the picture is an aftermarket bumper probably costing $400-$600 with tire carrier
eh, im pretty sure its not an aftermarket one. that is definitly a stock rear bumper...ill look through my pm's and see if i still have what balloo told me
2000 XJ 4.0
Old 04-11-2005, 01:04 PM   #8
agent9
yeah! I see it now. Only the first picture had loaded for me
Old 04-11-2005, 01:10 PM   #9
WhtJeep
2008 WK
Some kid has that here on Campus. I dont trust to to be honest. It looks like there are just a couple screws going into the factory bumper. There might be something else but it looks kinda shady for anything other than stock tires
2008 WK Khaki Grand Cherokee Rocky Mountain
1995 XJ Lifted and driven straight into the ground - RIP
Originally Posted by cresso
Quick dana 35 test: kick one of the rear tires. If the axle breaks, it's a 35
XboxGT - The Mad Med1c
WhtJeep is offline   Reply With Quote
Old 04-11-2005, 01:10 PM   #10
wjeepxj
tire carrier
I actually found one at a junkyard, and if i remember right there are pop rivits hold some of the interior bracing together( so be prepared). But over all it wasent that hard of an install. I just had to place the brace inside of the body and drill hole so it would line up, second had to die grind part of bumper out so the latch mechimism would work also, then i just welded it to my bumper. I carry a 31'' tire on mine. But when i the carrier is swung all the way out my bumper moves a little because of all the weight. I think 1 of 2 things can solve this though for you case and your 33'' tire. 1( you could brace the edge of bumper where carrier mounts or 2( you could shorten the limiter strap on the so you still would be able to open hatch back, but not have the carrier start to swing downwards. All in all it was a very inexpensive mod compared to buying a name brand, and works well.
wjeepxj is offline   Reply With Quote
Old 04-12-2005, 11:13 PM   #11
JEEPZZ
The one in the pics was a dealer installed option and is not OEM. It seems like we hash out this subject every month or two.
The only XJ OEM swing out carrier was available in the 80's XJ, maybe 'till 91?, but they can be fitted to all XJ's through 96.
IMO, the swing out carrier in the above pic is just as good if not better than the earlier OEM units.
Here's an excellent write up on installing a used OEM carrier from MadXJ.
[FONT=Trebuchet MS][size=1]97XJ RENEGADE
JEEPZZ is offline   Reply With Quote
Old 04-14-2005, 03:28 PM   #12
Mossyrock
Spare tire rack
My '94 Sport came off the lot with the swing-away spare tire rack. In all the years I have owned mine, I have only seen one other Cherokee with this rack. I have had several Cherokee owners ask me about it, and all I can tell them is that it came that way. Having the spare on the outside really helps open up the back end....LOTS more room.
[COLOR=DarkGreen][SIZE=5]Mossyrock[/COLOR][/SIZE]
[COLOR=Red]'94 Cherokee Sport, 4.0 HO[/COLOR]
145,000+ miles
-Flowmaster 40 series exhaust
-Black Unique Rock Crawler wheels
Mods to come:
-Cold Air Intake
-3.5" Lift
-31" Tires (Probably B.F. Goodrich ATs)
Mossyrock is offline   Reply With Quote
Old 04-14-2005, 04:25 PM   #13
covejeepsxj
I have a rear swing away in this style. I would be willing to sell it. What would anyone give me for it.
93 YJ, 4.0L, TF999, D300, D60's, Red Labels
covejeepsxj is offline   Reply With Quote
Old 04-14-2005, 07:25 PM   #14
ATX XJ
ill give u 150 if u can get me some pics
where u located?
Cherokee 4.0 4x4 231/AW4 30/8.25 BLACK
TEXAS LONGHORNS
ATX XJ is offline   Reply With Quote
Glock Forum
