sway bars - JeepForum.com
post #1 of 21 Old 07-31-2011, 09:37 PM Thread Starter
GTRJACK
sway bars
do i discount them when im off roading? sorry to ask this. its because im going threw the rubber bushings like crazy..
GTRJACK is offline
post #2 of 21 Old 07-31-2011, 09:39 PM
cdawall
1994 XJ Cherokee
mine are disco'd all the time. most people on here say thats the end of the world and recently got told that meant i didn't love my family. so don't suggest that however disco'ing them while offroad is the smart thing to do. more flex and no more early bushing wear.
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60u, 38.5s
Family SUV '94 XJ 3.55's, D30/35, 315/75R16's
cdawall is offline
post #3 of 21 Old 07-31-2011, 09:39 PM
whitexj98
Yes, it improves flex look into sway disconects.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 21 Old 07-31-2011, 10:53 PM Thread Starter
GTRJACK
so i should invest in quick disconnects?
GTRJACK is offline
post #5 of 21 Old 08-01-2011, 06:08 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes. Don't drive around with them disconnected on public roads, just off-highway.
cruiser54 is offline
post #6 of 21 Old 08-01-2011, 06:21 AM
Millermagic
Why not? I put probably 200 miles on my jeep both highway and off road with no serious problems.
I actually like the way it rides ...
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #7 of 21 Old 08-01-2011, 06:30 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Because driving around is alot different than having to do an emergency manuver at speed, losing control or rolling over, and causing harm to yourself and others.
post #8 of 21 Old 08-01-2011, 06:39 AM
cdawall
1994 XJ Cherokee
prove that the same accident was caused by no sway bar and i will believe you. i have put 7000 miles on mine since disco and it handles better than it did stock with the sway bars. a properly set up coil can do the same thing all a sway bar does is effectively double the spring rate. so a stiffer spring would do the same exact thing. it is also nice not having ones were i am because of how ****ty the roads are and ride is improved without them.
cdawall is offline
post #9 of 21 Old 08-01-2011, 06:42 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How about YOU prove it? Why don't YOU drive 65 MPH on the freeway and do an evasive manuver? You've been lucky. That's all. Enough said. I'm not beating this dead horse.
post #10 of 21 Old 08-01-2011, 06:44 AM
Millermagic
THIS x 10,000
I live in pothole heaven. TONS of pot holes. The fact that it's a solid axle vehicle and I'm running truck tires, made rides around the city almost unbearable with the pot holes.
With the swaybar disconnected, it's a MUCH better ride going through the potholes I can't avoid.
post #11 of 21 Old 08-01-2011, 06:45 AM
cdawall
1994 XJ Cherokee
i have. stupid truck driver decided to answer his phone and run me off the road. jeep handled just fine. if you do not feel comfortable knowing how to handle an SUV with no sway bars cool. i am fine as is my wife don't drive like a ******* and it can maneuver just fine.
cdawall is offline
post #12 of 21 Old 08-01-2011, 06:49 AM
Millermagic
Here's an idea, grab a stock cherokee with 225/75/15 tires, and BOTH front and rear sway bars, get it sideways and let us know the result.
Next, get a cherokee with 2'' of lift, 31s and no swaybars, and get it sideways. Either way, you're tipping over.
The cherokee is a unibody SUV with glass high up ... it's tipping over either way.
I look at it like this: I have a 11 year old suv with 105,000 miles on it, a lift and bigger tires. It has questionable brakes and tail lights that don't always work. I also have a Ford Focus that gets 40mpg ... Which is a better choice for the highway? If I'm on a wheeling trip and cara-jeeping somewhere, the 4 cyl wranglers on 34s can't go much above 45 anyway.
post #13 of 21 Old 08-01-2011, 06:58 AM
alexrule123
alexrule123's Avatar
Now I am calling bull**** on this, I drove a stock XJ with addco swaybars front and rear for 4 years and then went to a lifted xj. The lifted one is way more unstable driving around without the front swaybar connected and I personally don't like driving it on the interstate with it disconnected.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #14 of 21 Old 08-01-2011, 07:02 AM
Millermagic
I've noticed a bit more body roll in corners (IE the ones that say to go 45 around on the interstate and I keep going 65) but never have I felt unsafe without the swaybar.
The worst thing that happened with the disconnected sway bars is my 31s ripped off my front fender flares.
post #15 of 21 Old 08-01-2011, 07:25 AM
cdawall
1994 XJ Cherokee
How so. How do you know my coils/leafs are not stiffer leading to less bodyroll.
cdawall is offline
Bastard pack, sway bars, track bars. Slightly confused. andr3w XJ Cherokee Technical Forum 4 11-10-2009 03:13 PM
sway bars or no sway bars? DirtBound XJ Cherokee Technical Forum 24 01-23-2009 05:25 PM
sway bars - necessary?? motu1983 XJ Cherokee Technical Forum 15 10-14-2007 01:41 PM
Sway Bars: To Do Or Not To Do Jeppy XJ Cherokee Technical Forum 23 11-28-2005 12:32 PM
sway bars 89pioneer XJ Cherokee Technical Forum 9 03-04-2005 10:17 PM
