Sway bar link kit - JeepForum.com
post #1 of 9 Old 12-08-2012, 11:59 AM Thread Starter
blakes143
1991 XJ Cherokee
Sway bar link kit
Just realized I need a new sway bar link kit. I have a 4.5" lift. The only one that I have found so far that I can afford, the links have a curve in them but the ones on mine are(well are supposed to be) straight. Would this kit work or do I need to find some that are completely straight?
blakes143 is offline
post #2 of 9 Old 12-08-2012, 12:18 PM
sAe23
1995 XJ Cherokee
What do the original ones look like?
And this is an XJ forum...your info says you have a WJ?
Check out Roughcountry.com. Quick disco's are $60.
sAe23 is offline
post #3 of 9 Old 12-08-2012, 12:36 PM Thread Starter
blakes143
1991 XJ Cherokee
Yea I'm on the iPhone app idk how to change the info. I have an xj now.
They look just like these but without the curve.
http://www.4wheelparts.com/Lift-Kits...t_pn=EXP55597B
post #4 of 9 Old 12-08-2012, 12:37 PM Thread Starter
blakes143
1991 XJ Cherokee
This jeep is my daily so I don't need quick disconnect.
post #5 of 9 Old 12-08-2012, 01:06 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
http://www.ebay.com/itm/Jeep-Cheroke...a7f84f&vxp=mtr
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #6 of 9 Old 12-10-2012, 02:48 AM
sAe23
1995 XJ Cherokee
4.5" lift, 33" tires... no disco's?
You, sir, are abusing your Jeep!
sAe23 is offline
post #7 of 9 Old 12-13-2012, 06:24 PM Thread Starter
blakes143
1991 XJ Cherokee
I just bought it about 2 weeks ago.
post #8 of 9 Old 12-13-2012, 09:03 PM
rugsucka
Stock links have the bend in them to line up with the sway bar which is more narrow than the axle brackets, most aftermarket do not which can wear the bushings a bit sooner, but bushing kits are pretty cheap.
I fabbbed my own set of endlinks using a rod end at the top, so I don't have to deal with as mush bushing abuse. If you're handy and have the tools that's the way to go, but dagr8tim's link is a fine choice as are most other options from most offroad vendors.
rugsucka is offline
post #9 of 9 Old 12-13-2012, 09:12 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
These are what I put on mine. Not sure if they would work for 4.5 inches of lift.
http://www.ebay.com/itm/251156470260
dagr8tim is offline
