#1 | |
no whiners!
Swapped Cylinder Head
I had a thread way back when for how my coolant was mysteriously disappearing
![]() http://www.jeepforum.com/forum/f11/4-0l-losing-coolant-878140/ I had a cylinder leak-down test performed which it was clear that the head was bad. Here is were it cracked ![]() ![]() I pulled the head and set is aside. There was coolant in the #3 and 4 cylinders. I cleaned off everything and cleared the old gasket, which was intact and not blown. I checked the block for any visible weakness or cracks but could not see any. I am hoping for the best. Cylinder test failed at the head so we never made it down to the block. ![]() I installed the new head over a new Fel-Pro head gasket. Making sure to torque the bolts to 110 and #11 at 100. Thanks to Kettle's and CJ7-Tim who helped me out with the 00 Torque sequence ![]() Placing the exhaust and intake manifold was difficult because the reman-head did not have the dowels to line it up. I bolted it up loose so I could adjust it as needed. ![]() I put in a new Thermostat housing and bolted the rest in. ![]() I added some coolant and oil and fired it up. It ran rough for about 5 seconds before the computer adjusted the timing. It also smoke a bit because I got some grit/grim down into the intakes when connecting them to the head. That burnt off and it runs well. I still have the low oil pressure on the gauge but no milkshake in the oil so that is good. I am watching it closely. I will change the oil in a couple days and hook up a manual oil pressure gauge to see if I need a new sending unit which is likely. I'm not calling it finished yet because I don't want to jinx it. Thanks to everyone who helped me with this repair. ![]()
#2 |
I would change the oil right away. Who knows what kind of gunk got in there during your fix.
Edit: And congrats! |
#3 |
no whiners!
I did, last night. I ran some oil system cleaner with the new oil. I will change it in a couple days just to be sure. I want that thing clean. I might also drop the pan.
#4 |
How hard were the bolts on the bottom of the intake/exhaust manifold for you to get off?
#5 | |
no whiners!
I got them from the underside. Had to move the front drive shaft to get at them. If you have a head lamp or stationary light it helps a lot. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
