Quantcast swaping a 91 commanche d44 into an XJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > swaping a 91 commanche d44 into an XJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-10-2006, 11:09 PM   #1
pig_pen7
just picked up a d44 out of 91 commanche, wanna put this thing into my xj. I know the spring pearches have to be put spring over and the shock mounts gotta be changed, driveshaft??? what to do? Anyone done this before?
Any help or pics would be great. dgsmith7@telus.net
Thx Dave
pig_pen7 is offline   Reply With Quote
Old 04-10-2006, 11:16 PM   #2
twisted_ed
I would guess the ds might needs some work... best way to find out, measure from the center of the axle tube to the center of the pinion yoke then do the same on the dana 35 im assuming... and if they are the same, ur good to go, if its longer than the 35, then ull need to shorten it, if its shorter... then ull need to lengthen the driveshaft IF the difference in lengths are an extreme amount of length that the slip yoke in the Transfer case cannot handle it... again assuming ur using a stock tc without a sye
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
My Jeep
twisted_ed is offline   Reply With Quote
Old 04-10-2006, 11:32 PM   #3
1986Comanche
1986 MJ Comanche
Thx Dave
Last time I checked it was a Comanche... Not a commanche...
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed
Blue Jeep Club Member #123
Easy to be a truck. Hard to be a Jeep.
1986Comanche is offline   Reply With Quote
Glock Forum
