swap 3.08 gears into auto cherokee?
| RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Truck-Lite's New LED Headlamp Series | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
Hi all, any one swap 3.08 rearend and front end into an 87 automatic cherokee? Did it make it run like a dog? My daughter has an 87 xj with 3.55's. The rearend is howling like mad. I have complete 3.08 front and rearends that I could put in. The jeep is used for her to go to school, about30 miles one way and I don't want to make it a turd. Thanks for your help.
#2 |
Little Red Menace
I'd swap the rear but not the front as a temp fix. Remove the front DS and start looking for a cheapish 97+ 8.25 with 3.55s.
Stronger setup, less work, better use of time and money.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#3 |
Do you think the 3.08 would be too tall for the 4.0/auto combo? She doesn't wheel it at all, just needs 4x4 for when it snows. She likes it better than a car, says she feels safer in it.
#4 |
Formerly Alice Cullen
its going to be a slug
#5 |
Little Red Menace
It can be done, but would be close to putting 32s or 33s on a stock 3.55 set.
MPG may go down some and a bit lower RPM on the highway. Tell her to keep it in 3rd and go for it.
#6 |
....and 32 on 3.55 suck on hills, on flat ground its fine tho a good drop off in mpg too
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!! 62 mm bored throttle body's fs - pm |
#7 |
you could I guess
I would run no larger than a 225 75 r15. possibly as small as a 205. or it ging to be a total slug.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper. 94 yj: stock everything and 4 angry squarrels under the hood. |
#8 |
I would look around on your local craigslist and at the local junkyard. 3.08 with the auto trans is gonna be terrible. If you're mechanically inclined enough to put in a new axle, maybe you can just fix the one your have. It's probably just a bad bearing or something
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
