Suspension/Steering problem - JeepForum.com
post #1 of 4 Old 05-12-2014, 06:42 AM Thread Starter
zmasterflex
Greetings all. 1996 XJ approx 90K miles. I always had a problem when the 4X4 was engaged that I couldn't turn the wheel all the way to one side without the car having a fit. Now when I turn my wheel all the way to one side even without the 4X4 engaged it makes noise the resists the turn. When the car is in park its not problematic but when I try to drive ie; U-turn, K-turn and pulling out of parking spots it starts to sound like something is wrong. My alignment is straight and when I had it on a lift for an oil change the mechanic said that everything looked fine. Any thoughts? (I don't think it's the gearbox because when the car is in park I can turn the wheel all the way in each direction....) thanks
zmasterflex is offline
post #2 of 4 Old 05-12-2014, 07:22 AM
93gc40
It's either bad U-joints or improper use of the 4wd.. The only time you should use 4wd on pavement EVER is if you have a 242 Transfer case, with the shifter in the 4FT position. If you have a 231 case you should NEVER use 4wd unless you are on slipper road surface, ie dirt or snowy street.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 4 Old 05-12-2014, 09:52 AM Thread Starter
zmasterflex
thanks. How do I know which transfer case I have? 96 Cherokee sport 2 door
post #4 of 4 Old 05-12-2014, 11:29 AM
ParkerXJ
If its 231 then the shifting into 4x4 is like this from the lever
2wd
4hi
N
4lo
If its not then youve got the 242 tcase
2001 Jeep Cherokee XJ Limited -3.5" Rubicon Express Super-Ride kit, H4 headlights
ParkerXJ is offline
