Supercharger for XJ?! - JeepForum.com
post #1 of 5 Old 05-12-2009, 10:41 AM Thread Starter
kkalowski
1997 XJ Cherokee
I'm looking for a supercharger kit for my XJ but not an avenger kit, I want to know where I can buy the rick rimmer eaton supercharger kit that was put on the jeep in the article "4.0L Jeep XJ Cherokee Supercharger Kit - Hot Rod Hop-Ups" in '4 wheel and off road magazine'. I can't seem to find it anywhere and it's really aggravating.
kkalowski is offline
post #2 of 5 Old 05-12-2009, 10:47 AM
99Greenmachine
If my memory serves me correctly that kit was upwards of $3,000 and you had to buy a Wrangler intake.
Just get a Stroker mayne
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #3 of 5 Old 05-12-2009, 10:49 AM
slvrathlon
http://www.jeepforum.com/forum/searc...archid=4846882 --
Also from what most say, stroking the 4.0 is much better performance. I'm no expert, but just relaying from what I've heard and read.
slvrathlon is offline
post #4 of 5 Old 05-12-2009, 11:37 AM
Mr_Random
1986 XJ Cherokee
Look on Ebay for an Eaton Supercharger, design your own intake manifold, and nose shaft, then buy a boost controller?
A turbo might actually be less work, but a stroker will be completely drop-in, cheaper, and probably about the same work.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline
post #5 of 5 Old 05-12-2009, 12:30 PM
GreenMachine79
Also a turbo or super charger will put extra wear and abuse on a already aging engine. A stoker will do the opposite and give new life to the engine with new pistons, rings, bearings.....ect.
GreenMachine79 is offline
XJ supercharger xj_army XJ Cherokee Technical Forum 7 10-12-2009 09:13 AM
supercharger? CherokeeRT XJ Cherokee Technical Forum 3 10-21-2007 04:34 PM
SuperCharger 4x4life XJ Cherokee Technical Forum 17 10-11-2005 09:11 PM
Supercharger CHEROKEEMAX XJ Cherokee Technical Forum 17 03-02-2004 11:24 PM
Supercharger Ckwake135 XJ Cherokee Technical Forum 3 01-03-2003 09:55 PM
