Sudden gas mileage drop - JeepForum.com
post #1 of 16 Old 07-22-2008, 03:18 PM Thread Starter
woodie416
2011 JK Wrangler
So i got this problem. I used to average around 15-16 mpg city in my xj, but this last week or two i have been averaging around 10-12 mpg city. so could anyone tell me something that could be going on to cause this? and could you also tell me what your average mpg is. Thanks guys
woodie416 is offline
post #2 of 16 Old 10-19-2008, 06:18 PM
floridamud
i have the same problem right now, i dropped from 19mpg to 8mpg in one week, i think it might be the 02 sensors but i dont know
.... ___ ....................... _______
. /,[___], ..................../__/_,[___],
1---L-OIIIIIIO- ...........1--------L-OIIIIIIIO-
()_) ()_) ---- )_)........()_)--- ) ()_) ---- )_)
floridamud is offline
post #3 of 16 Old 10-19-2008, 06:24 PM
footypaul
Lot of places are going to 'winter blend' gas right now, and that will adversely affect MPG>
footypaul is offline
post #4 of 16 Old 10-19-2008, 07:01 PM
danno627
agreed. every winter I go from 15-16 to like 12. when they switch back to summer blend mpgs increase
danno627 is offline
post #5 of 16 Old 10-19-2008, 07:57 PM
compfreak530
makes alot of since. gas here just hit 2.79 a gallon. so it figures the cheaper stuff gets crappier mileage
compfreak530 is offline
post #6 of 16 Old 10-19-2008, 08:09 PM
xjpro
I think we are all suffering from the same. The mileage on my XJ has dropped from around 17 to 12 mpg which is driving me crazy. No CEL light whatsoever and everything seems to be ok, but I guess that our problem is that ďwinter blend gasĒ
So for this time letís not blame our XJís!!!
xjpro
01 xj limited
ZJ rear disc brakes with working parking brake
Electric fan conversion with spal fan controller
xjpro is offline
post #7 of 16 Old 10-19-2008, 08:14 PM
footypaul
Technically, the winter blend is more costly than the regular summer stuff. Oil prices are just dropping so quick right now that it doesnt show.
post #8 of 16 Old 10-19-2008, 10:13 PM
crcashman
I had been getting about 11-13 MPGs on Chicago's blend. I filled up a week after moving and got 16 MPG on the first tank. A few weeks later I did a basic tune-up and I've been getting a pretty consistent 19-20 in mixed driving and about 23 on highway trips. Its all in the blend.
crcashman is offline
post #9 of 16 Old 10-20-2008, 03:11 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Yup, mine has nose-dived in the past couple weeks as well, as it does every winter. I'm sure due to running winter blend, truck doesn't heat up as quickly in colder weather so spends longer time running rich, may keep ideling longer for heat, tire pressue goes down, etc., etc.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #10 of 16 Old 10-20-2008, 05:06 AM Thread Starter
woodie416
2011 JK Wrangler
haha yeah man for once its not the xj's fault
2011 JKUR 6 speed.
The Weekend Warrior
post #11 of 16 Old 10-21-2008, 06:08 AM
namichael
I had no idea that the blend of gas could play such a roll in MPG. Mine is doing the same thing. I thought that something may have been wrong with the XJ, because I had just recently changed the oil, air filter, replaced the PCV hose, and ran some fuel injector cleaner through it and then the loss of MPG.
Glad to see it's not just me.
2000 XJ Sport
ALL STOCK =(
namichael is offline
post #12 of 16 Old 10-21-2008, 06:57 AM
BigD 275
Yep, definitely the gas (as long as the car seems to be running properly other than the mpg decline).
I lose about 3-4 mpg every year once the gas stations start carrying the winter blend gas.
Also, the problem is on a cold start up as well. The computer is telling the engine to use more fuel until it reaches operating temperature, which obviously takes longer when it is cold outside.
99 Jeep Cherokee Limited
BigD 275 is offline
post #13 of 16 Old 10-21-2008, 08:02 AM
rust64
1994 XJ Cherokee
I wonder if it might help to disconnect the battery, and wipe the computer memory. Maybe it would help to let the computer relearn its' optimum settings. Don't know for sure, but it doesn't cost anything to try it.
rust64 is offline
post #14 of 16 Old 10-21-2008, 10:19 AM
jebmccall
1997 XJ Cherokee
hmmm i am having opposite affects here in ga, mine went up about 2
jebmccall is offline
post #15 of 16 Old 10-21-2008, 05:46 PM Thread Starter
woodie416
2011 JK Wrangler
lucky you man!!
2011 JKUR 6 speed.
The Weekend Warrior
Mileage drop after major tune-up? crowncaprice XJ Cherokee Technical Forum 4 05-30-2009 05:15 PM
gas mileage drop with BB? MXdude105 XJ Cherokee Technical Forum 10 06-03-2008 09:40 PM
sudden drop of oil pressure cifer6425 XJ Cherokee Technical Forum 5 12-01-2007 05:33 AM
sudden 50% drop in mpg - any idea what it might cause it? josephmartins XJ Cherokee Technical Forum 4 09-25-2007 07:57 PM
sudden drop to 1k rpm then back up 87bucket XJ Cherokee Technical Forum 3 09-11-2006 01:47 AM
