#1 | |
Beach Jeeper
Sub Frame Repair
I will post some pics later, but the sub frame on my xj is rusty. Some places have some bad rot. Has anyone repaired these and how did you do do it? Thanks
#2 |
XJ on 37's
what are you classing as the sub frame exactly?
and yes we need pics. martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#3 |
LLaP \\//,
pics pls, and by sub frame do you just mean the undercarriage of your Jeep?
Really depends on what's rusted and how bad it is, there are some parts of the frame that really cannot be repaired when rusted out too harshly (I know this because I learned the hard with with my ZJ) |
#4 |
Beach Jeeper
the two main rails that travel to length of the body, transmission crossmember is attached to. I get off work this evening, ill take some pics then.
#5 |
You need pics to detect anything..... Sounds like a big job though
#6 |
Depending how bad it is, you may be able to repair it using the frame stiffeners from TREKS. www.gotreks.com
#7 |
Beach Jeeper
![]() [IMG] http://i937.photobucket.com/albums/ad211/xjmedic/XJ%20Build/IMG00289.jpg[/IMG] |
#8 |
that is not good. is right next to the leaf spring mount?. that is going to be a lot of work.
#9 |
Is that the worst of it, or does it wrap around inside the leaf spring mount? In the first pic, it looks like there is a hole rotted in the side of the frame rail..can we get more pics of that?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
