stupid stupid question...check engine light
| Truck-Lite's New LED Headlamp Series | TJ 5.25" Speaker Adapters - NalinMFG | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! |
#1 | |
hey everybody
if some of you may have seen my thread...stumbles, almost dies, then runs fine, well this relates to that. i have a check engine light. how can i check to see what code im getting?? thanks
#2 |
What year is it? On my 94 their is a way to turn the key in a certain way and you get the check engine light to blink a code that tells you what is wrong. I have also heard of autozone or somewhere similar having a scan tool to get the codes.
#3 |
Youngin'
if u take it to autozone they will read the code for u for free and try to help u out and diagnosis the problem
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#4 |
ok..well i went out and just did the on-off, on-off, on thing and the check engine light started flashing. do i count the total number of flashes or what??
#5 | |
it will flast a series of times, like flash-flash-flash....then it'll wait like 3 seconds, then flash-flash....then wait 3 seconds......the flash-flash-flash-flash. that would be 324. look online to find what it is...not that you have a DTC of 324...that would be weird |
#6 |
will it only do the series once...because it seemed like if it didn't my number would be something like 1, 3, 2, 5 6
#7 |
im definately not getting any kind of 3 second pause..how many digits are supposed to be in the code at MAX. im thinking mines around 4-5 maybe 6 digits long
#8 |
oh, and they'll only do OBD2 or 96+ cars...not the older ones...sorry.
#9 |
wait so on my 95 cherokee it wont do the flash thing cause my check engine light comes on all the time and i dont know how to check it to see what it wants me to check. what do i do (if there is anything i can do) to check it?
Thanks, Jack |
#10 |
I'm hopefully not trying to pirate a thread but I think I speak for some of us when I say can we have the different ways to do this on different systems.
I've tryed the key thing on my 99 and it doesn't work and I'd like to know what I'm doing wrong ![]()
Either our language or our culture needs to be expanded/improved so that there is a polite way to say: Stop talking now, because I am going to stop listening. 99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear. |
#11 | |
as for the other guy, it will be 3 digits, and the pause is 1.5 seconds between flash to flash, and a 3 second wait between numbers. one set of flashes is the first number, after the 2-3 second wait is the second number, and then another 2-3 second wait for the third. about this much time between flashes....hits head about this much time betwen numbers.....drool hits ground. |
#12 |
I have posted this link so many times, Go Jeep is probably getting tired of it.
CODES AND DIRECTIONS. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
