Stupid question, but........ - JeepForum.com
post #1 of 5 Old 05-25-2012, 10:11 AM Thread Starter
ibjeepin95
I feel like an idiot asking this, but does it really matter which way you mount a shock?
ibjeepin95 is offline
post #2 of 5 Old 05-25-2012, 10:32 AM
DriverX
It depends on the shock type. Most have a valve that requires them to be mounted a certain way. On higher end shocks there is an arrow or UP direction indicating install position. Some hydro shocks can be mounted either way. The majority of gas charged shocks can only be mounted one way.
Worst case, call the manufacturer and check with them if there are no markings.
DriverX is offline
post #3 of 5 Old 05-25-2012, 10:36 AM
sAe23
1995 XJ Cherokee
It *can* (I would ask the manufacturer), but what with the weight of a live axle, do you really think you're saving anything significant by inverting a shock?
And then there is the cost of adapters needed to mount generic shocks...
sAe23 is offline
post #4 of 5 Old 05-25-2012, 10:51 AM
motoxxxman
1995 XJ Cherokee
shocks for an XJ can only be mounted 1 way, so it'd be impossible to put a shock on incorrectly inverted, unless you're doing some custom setup
motoxxxman is offline
post #5 of 5 Old 05-25-2012, 11:48 AM
Pats94
We used to do it to save upsprung weight but I never saw any diff.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
stupid stupid question...check engine light iwishihad1 XJ Cherokee Technical Forum 11 05-16-2007 09:17 PM
Stupid Question But.... bmyohn XJ Cherokee Technical Forum 3 11-27-2006 05:52 PM
One Stupid Question...One not so stupid (I hope) xjrrrdx XJ Cherokee Technical Forum 1 08-02-2006 11:01 AM
stupid (maybe not that stupid) brake question dirt machine XJ Cherokee Technical Forum 10 05-02-2006 04:12 PM
Probably a stupid question but... DON BRODIE XJ Cherokee Technical Forum 4 02-16-2005 01:24 AM
