stupid evac check engine and smog check - JeepForum.com
post #1 of 11 Old 10-31-2008, 02:55 PM Thread Starter
ksturgio
I really need some fast help. I live in Las vegas and i own a 2001 cherokee. I had the Jeep for about a year ( original owner) when it threw an evac code replaced the gas cap and still didn't fix the problem. To pass an emissions test here the engine light can not be on. In the past i have just disconnected the battery to reset the cpu. When i did this yesterday for my test the guy said that because i reset the computer the test failed because the sensors dont register until you drive 70 miles. So today being the 31st im scrambbleing to get this done. I am thinking about getting a scanner to clear the code to turn the light off. Ive been looking for any problems in the evac but can't find any. Should i buy a scanner or does any body else have any ideas. Thanks a ton.. P.S. screw those washington bastards who pass the stupidist emission laws known to man. I cant wait to get my 71 chevy on the road with exhaust cut outs to show them some emissions.
ksturgio is offline
post #2 of 11 Old 10-31-2008, 03:20 PM
purpose-built
you can "borrow" a scanner from any Auto-zone, they will check your code for free and sell you the parts you need . good luck
purpose-built is offline
post #3 of 11 Old 11-01-2008, 01:53 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
There is a fairly common problem with the newer XJs and the small rubber hose on the Evac system. I will try to find the thread that walks through the $1 fix for this problem.
**Edit
http://www.jeepforum.com/forum/showt...sions+canister
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 11 Old 11-01-2008, 01:45 PM Thread Starter
ksturgio
balloo93 thanks for the link. This morning im going to check the whole evac system and canister. I'll be sure to let you know how it turns out. Apparently my brothers 98 Wrangler just threw the same code. Before you know it I'll be an evac specialist.
ksturgio is offline
post #5 of 11 Old 11-04-2008, 10:54 AM Thread Starter
ksturgio
Well i checked all the lines and they seem fine. Is there any way i can test the evac canister at home i would just buy a new canister but thats a $100 and i dont even know if thats the problem. Any suggestions.
ksturgio is offline
post #6 of 11 Old 11-05-2008, 01:59 PM
cubsin2079
Do you know the code being thrown? If not find a code reader on sale or go to autozone and post the code they tell you!!
SUSPENSION: OME CS035RA HD leafs w/OME AAL. Ironman Fab 1.5 in boomerang shackle, RE 3.5 coils w 3/4 spacer, Ironman Fab adj UCA + LCA, JKS discos, JKS adj. trac bar, OME long travel shocks.
ARMOUR: AJ's Super Sliders, JCR belly skid, Mopar gas tank skid, OR-FAB quarter panel armor, Ruff Stuff diff covers.
Rolling gear: Rubicon Moabs, 245/75/16 MTRs, IRO hack-n-tap SYE. Aussie locker in front, Powertrax no-slip in rear.
Uniden 520proxl, Hella 500s, rock lights.
cubsin2079 is offline
post #7 of 11 Old 11-10-2008, 06:19 PM Thread Starter
ksturgio
OK i bought a scanner for $100. I looked and looked and couldn't find anything wrong with cracked lines or fittings or anything. I broke down and took it to a mechanic for the smoke test ($127) He fixed tyhe leak for free. Thanks for all the help and keep on wheelin!
ksturgio is offline
post #8 of 11 Old 11-11-2008, 05:54 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Where was the leak? Don't leave us hangin like that!
93 Sport
Specs in Profile.
balloo93 is offline
post #9 of 11 Old 11-11-2008, 09:53 AM
dz1087
dz1087's Avatar
No kidding - that's like a bad ending to a date that was going well.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline
post #10 of 11 Old 11-17-2008, 02:56 PM Thread Starter
ksturgio
The d-bag wouldn't tell me last time i go there.
ksturgio is offline
post #11 of 11 Old 11-17-2008, 03:19 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Glad to know Im not the only one with this experience.
88XJSport is offline
check engine light on 2000 cherokee.. can i check it my self? Magic2979 XJ Cherokee Technical Forum 27 12-11-2013 08:46 AM
Check engine light came on. Is there a way to check the code? mhall101 XJ Cherokee Technical Forum 11 01-08-2012 07:01 PM
Calif smog check info Highway 4x4 XJ Cherokee Technical Forum 1 01-12-2009 06:50 PM
stupid stupid question...check engine light iwishihad1 XJ Cherokee Technical Forum 11 05-16-2007 09:17 PM
smog check FAILED!! what needs to be fixed? assang XJ Cherokee Technical Forum 7 03-23-2003 12:38 AM
