Stumbling at idle but drives ok?? 96xj 4.0 - JeepForum.com
post #1 of 4 Old 11-16-2007, 04:37 PM Thread Starter
ChaoticBastard
Ok this jeep I am selling just today starting acting up.Its a 96,4.0 Auto with 146 on the clock. I started it for the first time in 3 days and it starts right up like usual. I noticed it started to buck,hiccup a little at idle.So I knew it was low on gas,I put 5 gals in it. No Change, I added a bottle of Cleaner no change.
It only does it in idle and in park.Put it in drive and it idles fine. A little shaky sometimes in drive but usually good. It drives like normal. Turn it off and start it again. It runs great for about 2-3 minutes then it starts stumbling again. I pulled the codes with my cheapo scanner when i got it. and it said 4 codes then. All o2 sensor related. Now I ran it after this and it is only showing 2 codes 132 and 138. High voltage o2 readings. I am not going to mess with it. I dropped the price way down and just want it gone. Any idea on what it could be besides the o2?? Thanks
2009 Mustang GT Premium
2012 JK Sport
MetalHead Jeep Club Member #33
Originally Posted by kairo
what's wrong with bombing poor people? It has all the awesomeness of bombing combined with removal of crime. It's like a win win situation.
Unwad your panties
ChaoticBastard is offline
post #2 of 4 Old 11-16-2007, 06:52 PM
tangofox007
Tps.
tangofox007 is offline
post #3 of 4 Old 11-17-2007, 01:11 AM
collkid
Fuel Filter/pump?
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline
post #4 of 4 Old 11-17-2007, 04:19 PM
dopod
dopod's Avatar
Bad cat converter can cause stumbling and they were recalled on 96 xjs. You can pick up a new one at the dealership for free. Hit your converter and see if it rattles. If it does it's bad.
dopod is offline
96xj no power...pcm? jeepxjkid XJ Cherokee Technical Forum 4 01-14-2010 12:06 PM
99XJ alt. fit on my 96XJ? Ronron2112 XJ Cherokee Technical Forum 3 12-05-2009 01:59 PM
96XJ A/C problems AdrianD XJ Cherokee Technical Forum 0 07-25-2009 12:15 PM
97+ flares on a 96XJ? XJ_DIESEL XJ Cherokee Technical Forum 6 03-07-2007 06:09 PM
258 into 96xj?? 40lxj XJ Cherokee Technical Forum 5 12-02-2006 01:35 PM
