Stumbling from idle to about 2900? - JeepForum.com
post #1 of 2 Old 05-11-2010, 08:36 AM Thread Starter
GrayBomb
1989 XJ Cherokee
Hi,
I did a few mods now I am stumbling from idle to about 2900rpm. Its not terribly slow but you can feel/hear it has a small stumble, like if it may be lean, until 2900 and then it pulls all the way up. Just looking to see if anyone here has any ideas.
Rig: 89 XJ
Rebuilt motor about 60k on it (Renix FI and Renix Head)
Borla header heat wraped
2.5" cat/catback
99+ intake manifold
Injectors from a 98
Fuel pressure right now 57psi trying to make up for lean condition
Taurus fan swap
Map adjuster set to 5.56 volts
Homebrew CAI w/relocated IAT sensor
Thanks,
JR
For Sale: 89' Limited w/ Renix. Performance:Custom Cold Air Intake, Air Temp Conversion, Map Adjuster, Throttle Body Conversion Bored, 99+ intake manifold, 98 injectors w/ 99 fuel rail, bumped fuel pressure, Borla Wrapped Header, 2.5 in exhaust header back, open loop cooling, electric fan conversion, SS brake lines, 96+ brake booster and still getting 20 mpg highway
GrayBomb is offline
post #2 of 2 Old 05-11-2010, 08:47 AM
irishgobrah
1995 XJ Cherokee
How long has it been since the fuel filter has been replaced? Hopefully it's something as simple as that.
-Casey
93 XJ :Rusty's 3" w/ 31x11.5 swampers-hooked my brother up
96 XJ :Rusty's intake/exhaust kit-hooked my dad up
00 WJ :clear lenses from an 04-wife's DD
95 XJ :2dr slowly coming along!
irishgobrah is offline
cherokee , lean , performance , renix , stumble
Still Stumbling! Need Help! kongpheng XJ Cherokee Technical Forum 13 11-03-2008 06:09 PM
So I got a 98 Classic yesterday for $2900 Dexafaust XJ Cherokee Technical Forum 8 03-01-2008 08:53 PM
Stumbling at idle but drives ok?? 96xj 4.0 ChaoticBastard XJ Cherokee Technical Forum 3 11-17-2007 04:19 PM
stumbling now and then?? shierkahn XJ Cherokee Technical Forum 13 12-02-2006 12:59 PM
92' laredo worth $2900? Harrison XJ Cherokee Technical Forum 18 12-11-2005 08:17 PM
