Stuck in Part-Time!!! Please Help!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Stuck in Part-Time!!! Please Help!!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 12-31-2002, 03:21 PM   #1
ddoffroad
Today I used my 4wd to get through some mud, then when I can out and switched in back into 2wd it would not disengage. Its stuck in part-time. When I put it in Full-Time there is no display but it sill feels on. I have tried moving the handle in all posiiton and wile the main shifter was in nutral. The T-case will switch into 4-low and 4-nutral but it wont go to 2wd. I seem to also be leaking a clear sticky fluid onto my driveway, but it doesnt seem to be comming from my t-case, it seems dry. Could it be a vaccum? I need to figure this out before Thurs when I'll take it to a mechanic! THANKS IN ADVANCE!
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad: http://ddoffroad.com/
My XJ site: http://www.cardomain.com/ride/2488225/
My Old XJ Site: http://www.cardomain.com/ride/2058746
ddoffroad is offline   Reply With Quote
Unread 12-31-2002, 11:07 PM   #2
MJR
If you have the 231 t-case then it could be the vacumn actuator sticking on the front axle or the switch on the t-case. No vacumn and it should disengage.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline   Reply With Quote
Unread 01-01-2003, 09:39 AM   #3
ddoffroad
i think meybe im loosing t-case fluid and thats making it sick. It sure does not sound pretty! How do I release the vacuum?
Unread 01-01-2003, 12:39 PM   #4
MJR
You can just unplug the vacumn lines but if the spring is stuck (makes it move to open) then the only way would be to pull it apart.
"Got Groceries"
88 Jeep Wagoneer
Unread 01-02-2003, 01:52 AM   #5
91XJLimited
T-Case fluid is Automatic Tranny fluid. It will be red.
91 XJ Limited - RE 5.5" XD, 32x9.50 TSL's, 4.0 HO, disconnects, other good stuff
94 ZJ 5.2 Limited - 6.5" Teraflex lift, Clayton Long Arms, disconnects, 37x12.50 SSR's, Hummer Beadlocks, and more good stuff
[SIZE=4][URL=http://www.geocities.com/lovaboy1599/My_Jeeps.html][color=red]MY JEEPS[/color][/URL][/size]
91XJLimited is offline   Reply With Quote
Unread 01-02-2003, 12:47 PM   #6
Scafone
I don't know if Cherokee & TJs use the same actuator & such, but mine has been doing the same thing for a little while now. It's not always hard to come out of 4wd to 2wd, but sometimes it is. When it doesn't come out right away, either accelerating/decelerating hard seems to get it to shift...but sometimes it happens with a bang, too.
Can this actuator be cleaned out? I've never tried to look for it.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline   Reply With Quote
Unread 01-02-2003, 01:35 PM   #7
MJR
No it's a sealed/crimped vacumn actuator.
"Got Groceries"
88 Jeep Wagoneer
Unread 01-02-2003, 03:20 PM   #8
ddoffroad
u-joint
I couldnt figure it out, so I took it in. It turns out it was a majorly bad d-side front U-joint. The mechanic said that the 4wd was disengaging but it didnt feel like it because the u-joint was buckling. So im gonna get it back from him and replace the u-joint myself and save the ca$h! Does anyone have tips on how to replace an axle U-joint?
Unread 01-02-2003, 03:26 PM   #9
MJR
Makes sense if it was binding. They can be fun to change it they are coroded at all. You can either use a big vise and a coupl of sockets or a ball/U joint press. The C clips usually break when you try to get them off but that is ok the new U joint should come with them. Do you know if you have the 260's or 297's ?.
"Got Groceries"
88 Jeep Wagoneer
