Stuck in Part Time - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Stuck in Part Time
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-02-2003, 10:58 PM   #1
Islandroaddie96
Stuck in Part Time
Alright guys, just when I thought that I was on top of the world and everything was working perfectly, I discovered that I can no longer shift into 2wd (I stay in Full-Time year round) without getting stuck FOREVER in Part-Time.
The agonizing part of it is that the XJ will go into a sort of 3wd mode (locker?) where you must have the wheel about 15 degrees to the left to stay from going off the road. After pulling into a parking lot and going back and forth 5 million times, I was finally able to successfully get back into Full-Time. No problems while in there whatsoever.
My question is. . .
WTF IS WRONG? Could this be a simple thing such as the selector needing adjustment, or is the problem in the front axle or transfer case itself. I have a '96 so I don't believe I have the vacuum disconnect, but honestly, I've never checked.
It has about 97,000 miles on it, most of those spent in Full-Time 4Wd.
Grrrrrrrr I really want to fix this so I can do some intense peel-outs on demand
Thanks in advance,
Peter
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline   Reply With Quote
Unread 11-03-2003, 01:04 AM   #2
EricsXJ
The Post man
EricsXJ's Avatar
Are any of the linkages underneath bent?
Just a guess...
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Unread 11-03-2003, 10:47 AM   #3
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
When was that last time you changed the ATF in the t-case. Maybe its dried up and won't allow it to shift. Just another guess???
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Unread 11-04-2003, 04:53 PM   #4
Islandroaddie96
Just a guess...
Good Question. . . I wouldn't know exactly what to check or how I'm supposed to know if it's bent, but I could take a look. I don't recall any situation where it landed or hit something in a way that could have bent something.
Right now I am thinking maybe just the selector is out of adjustment - ie. the shifter is not moving far enough forward to fully disengage from PT to 2wd. (Except I don't know if that would explain why it is so difficult to go from PT to Full Time).
BTW, I have done absolutely nothing to modify the driveline; no lifts, axle mods etc, and it has no difficulty going from 4lo to Full Time. I will check the fluid too.
Thanks your for your replies.
1996 XJ Sport
Unread 11-09-2003, 01:50 PM   #5
Islandroaddie96
Ok, now I definately think that the shifter is out of adjustment because there isn't anything else I can find wrong. I remember reading a few weeks ago on here about how to realign the shifter properly but I can't find that thread. Can someone refresh my memory please?
Thank You very much,
Peter
1996 XJ Sport
