stuck in part-time 4-wheel drive
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Our youngest son borrowed our 1992 Briarwood with Selec-Trac to help
a friend move. When my wife went to drive she found the dash indicator light for part-time 4-wheel drive on and could not shift out of this mode. I have also been unable to return to 2-wheel drive. We are new Jeep owners and would greatly appreciate any suggestions. JeepForum was very helpful with our first problem. Thanks, Pit Partner and wife
#2 |
I had the same problem with my 1987 Cherokee. I learned that I had to backup to get it out of 4wd. You could hear it click out after 5 or 6 tries.
2000 []lllll[] XJ Classic (Moms) 1996 []lllll[] XJ Classic (My Work Vehicle) 1996 []lllll[] XJ Sport (Run Around Jeep) 1987 []lllll[] XJ Cherokee Chief 2 door 1995 ()lllll() YJ Rio Grande |
#3 |
Thanks Pattonsky!
Pattonsky,
Thanks! Your suggestion worked on the fourth try. This forum is such a great resource. Experience from all of you is worth more than all the manuals and books out there. Pit Partner (and wife) |
#4 |
When a selec-trac is stuck in a specific gear (usually full time hi)
get a flat stretch of road (dirt or a loose surface like gravel is better) drive forward with the wheels perfectly straight at like 5-10 mph and pull the handle smoothly back with a little bit of leftward pressure so you dont pull it back to neutral. when its fully against the stop and in the full time position, continue driving at least 20 or 30 feet. it may take a few release/taps of the petal to switch to full time and have the green light come on. -if the green light DOES come on and the amber goes off, then continue driving forward slowly, and in one strong fluid motion, push it all the way forward to the 2wd position without stopping in the part time position. the light should turn off and it shouldnt go back to part time. Once it does this, reverse at 5mph for at least 15 yards... The TC should be unbound and function normal now. -If even in the full time position, the orange light stays on, then reverse for about 15 yards, see if anything changes. drive forward slowly, then while driving push the handle forward to the 2wd position in one strong fluid motion without stopping at part time. tap/release the gas and see if the light turns off within 30 or 40 yards If not, reverse again for about 15 yards and see if the light turns off. If the light is STILL on amber, drive forward and turn the wheel sharply to full stop, then a tiny bit out to keep from straining the steering box, see if it hops or seems to bind the front axle. If it DOES bind up and act weird (like its popping something) then likely your transfer case is damaged and wont shift. It may be the shift linkage or the internals. If it DOES NOT bind up, then your TC should be fine, and the sensor that tells it what position its in, is stuck on part time.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups. PS: Installing HID's in stock housings is bad. Here is why. "When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009 |
#5 |
Thanks madrabbit
Madrabbit,
Thanks for the imformation. I am going to make a hard copy of this procedure and keep it in the glove box just in case the problem reoccurs. Is this common for Selec-Trac equipped vehicles? I really apreciate the time you took to explain what to try. Pit Partner |
#6 |
Yes it's common, mine does it too. It doesn't seem to affect anything other than it's annoying to get out of 4wd. I put it in neutral and decelerate at the same time and it usually pops out right away.
#7 |
i've had three vehicles with a version of this transfer case. my current cherokee, my old cherokee, and a dodge at my former ems agency.
i've noticed, that the selectrac transfer case is more likely then command trac to bind when run in part time on solid paved surfaces. The list of instructions has come from many years of trial and error (mostly error) with this transfer case. i personally love the selectrac, and it's been the deciding factor on two purchases, and 4 non purchases, when it's come to my jeeps.
#8 |
Command TRac.
I have a similar problem with an 88 cherokee with the Command Trac set up. The front axle disengages , but the transfer case remains engaged and the "part time" light stays on. This happened after Katrina hit when I was pulling trees out of the road with my cherokee. Will the same techniques for the select-trac setup work on the command trac?
#9 |
very likely not.
the selec-trac's full time position allows a transfer of tourqe from front to back. since the front and rear diffs arent locked togther, it allows the TC to unbind. you could, of course, try it. It wouldnt hurt it anymore.
#10 |
I had a problem, stuck in AWD on my 99 Select trak w/ 90 k or so miles. Took it to dealer who changed fluid in AWD transfer case and then it worked.
According to dealer, the AWD shifts INTO AWD with the lever and OUT of AWD w/ fluid pressure, so worn fluid does not have enough pressure to get you back into 2wd. |
#11 |
I dont know if mine works the same way, but i'm sure it could use a fluid change. Thanks for the idea.
#12 | |
yes, fluid pressure plays a large part in the shifting of the transfer cases.
#13 |
umm, my t-case np231 had about 2 table spoons of fluid in it, shifted perfectly
the chain came loose from lack of fluid tho. how does fluid pressure have anything to do with a mechanical shifting t-case? |
#14 |
The basic answer is by reducing friction and providing a boundary layer of fluid that keeps the metal from grinding.
#15 |
-Now I've read about everything on this before posting. Nobody really has the set up I have because they're discussing newer jeeps.
-My Select-Trac switch is seperate and by itself behind the shifter. -1. I don't get a display of what Im in on the dash (some other problem maybe) -2. I'm in 4 High all the time. I know this is cuz the H is lit up where I can switch from H to L -3. When i pull the lever to try and go to 4L it doesn't pull back all the way. Can't even pull it to N. -4. When I hit the Select-Trac switch to try and get to 2wd I hear air around the switch. Any ideas? It's an 86' jeep, but only 140k miles.. Good motor, Just have this problem and I drive it too much right now to not be able to get 2wd. Last edited by pierceandrew1; 09-07-2008 at 02:49 AM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
