STuCK OIL PAN BOLTS - REAR MAIN SEAL - WT*?! - JeepForum.com
post #1 of 6 Old 12-13-2011, 04:01 PM Thread Starter
meangreen909
As I am removing all the oil pan bolts and studs I approach the last two that are on both sides of the main seal. I tried to remove them but I cant because they are wedged there so bad that I can get the socket and if I did it wont be able to turn because one of the edges on the bolt is completely flush to the oil pan lip.
WT* IS THIS ABOUT?
meangreen909 is offline
post #2 of 6 Old 12-13-2011, 04:39 PM
mtb_crzd47
You can get a socket in there, it just takes a little finesse and a lot of extensions. It may help to remove the inspection plate on the tranny as well. Sounds like you may need to persuade the lip out of the way a little bit, be creative with this one, just not dumb.
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
mtb_crzd47 is offline
post #3 of 6 Old 12-13-2011, 09:48 PM
Reptile
1991 XJ Cherokee
You could stick a slim chisel between the bolt and the pan to make room for the socket. The pan is aluminum and is somehow flexible, just don't damage it too much cause it'll bend. Also try to find a socket with slim edges.
Reptile is offline
post #4 of 6 Old 12-14-2011, 02:59 PM
rjbruzan
Put the socket on an extension and tap it on with a hammer. The end ones are a different size than the side ones.
Ron
rjbruzan is online now
post #5 of 6 Old 12-14-2011, 04:30 PM
AZ Jeff
2014 JK Wrangler
Actually the pan is steel, but yes, it can be bent/pried out of the way.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 6 Old 12-15-2011, 06:09 AM
mbardeen
1995 XJ Cherokee
I got mine out using a 1/4" drive and a ton of extensions. The bolts can be removed with either 1/2" or 13mm socket. Getting them back in required a bit of tapping with the hammer to get them tightened all the way down.
mbardeen is offline
stuck upper rear main seal...ideas? XmuthJ XJ Cherokee Technical Forum 16 12-30-2015 08:02 AM
rear main seal vs torque converter seal blacksunshine XJ Cherokee Technical Forum 3 04-21-2011 03:57 PM
Rear main top seal stuck.. Swampwalker3 XJ Cherokee Technical Forum 8 03-23-2010 06:30 PM
2001 Rear main seal 'tabs' on replacement seal, but not OEM (did search) akxj01 XJ Cherokee Technical Forum 2 11-12-2008 07:22 PM
HELP - Upper rear main seal stuck xjkevin89 XJ Cherokee Technical Forum 8 02-27-2007 04:06 PM
