Stuck in Four Wheel Drive - JeepForum.com
post #1 of 12 Old 01-18-2006, 08:04 PM Thread Starter
Thelt
2005 KJ Liberty
My jeep is getting stuck in four wheel drive. After it sits for about thirty minutes with the lever in two wheel drive position then it will actually go in to two wheel drive. The lever moves freely it just does not cause it to disengage the four wheel drive. Any thoughts on this? Could it be a vacuum issue?
2005 KJ Sport 4x4
1998 ZJ with inline 6
I hate environmentalists, they keep me from enjoying the environment.
Thelt is offline
post #2 of 12 Old 01-18-2006, 08:26 PM
Jeepernick
Jeepernick's Avatar
2008 XJ Cherokee
Well from experience I know that the best thing to do for the cases sake is to back up if you take it out of 4wd, I always do it or I dont take it out tell I can back up, just a few feet and you will hear or feel it pop out of 4wd
Give it a shot, Good luck
Jeepernick is offline
post #3 of 12 Old 01-18-2006, 08:29 PM
nitrocarmsn
yea i back up too when i take it out of 4wd, works everything, i even do this with my dads 03 dodge ram hemi 4X4, eventho its "shift on the fly"
95 xj sport black, 4.0L HO, AW4, NP231, dana 35C, tow hooks and hitch, skids all around, rewired aux. fan for switch, air shocks in rear, apache A/T's, pioneer head unit, 2 sony explode subs 1100W each, Dual 460W amp, ex military vehicle.
nitrocarmsn is offline
post #4 of 12 Old 01-18-2006, 08:32 PM
Jeepernick
Jeepernick's Avatar
2008 XJ Cherokee
Well the jeep does to, but it is beyond that. Just puts the front end out when you back it up
i shift in to 4wd doing 40, but I take it out stopped and then back up
NOTE: ONLY shift into 4lo, stopped and in N
post #5 of 12 Old 01-18-2006, 08:33 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
Even if the vac. disco isn't working properly the TC is what activates/disengages the front driveshaft. Make sure the lever is all the way down and try backing up. If that dosn't do it, check the linkage on your TC.
LEAD_NOT_FOLLOW is offline
post #6 of 12 Old 01-18-2006, 09:38 PM
anony91xj
Check the fluid level and contidion in the Tcase. Which case are we talking about here, 231 or 242?
1998 VW GTI 2.0
anony91xj is offline
post #7 of 12 Old 01-19-2006, 07:46 AM Thread Starter
Thelt
2005 KJ Liberty
Backing it up is the first thing I tried. It did not work. I have had other four by fours which needed you to do that but it is not helping here.
I have the transfer case that has the part time mode, full time mode, and the low range. I put it in full time mode and then when I try to go back to two wheel mode it is getting stuck in part time.
2005 KJ Sport 4x4
Thelt is offline
post #8 of 12 Old 01-19-2006, 08:09 AM
JoBo
That would be the 242 "full time 4wd" transfer case then. Most have the 231 "part time 4wd" case
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #9 of 12 Old 01-19-2006, 09:41 AM
saxj
Try gunning the throttle and backing off, that usually does it with mine. You may need to do it a couple of times.
When I got my Cherokee, it had never been used in 4wd, and when switching between FT and 2wd it also used to get stuck for quite a while, now it shifts quickly.
1996 Cherokee Limited 4x4
OME Springs, 30x9.5 M/Ts, 4.0 HO Auto, NP242
saxj is offline
post #10 of 12 Old 01-19-2006, 09:50 AM
Jeppy
Jeppy's Avatar
mine does it too. when I shift from full time to 2WD it gets into part time. I usually have to back up, sometimes a few accel - decel cylcles does it, I think it's common
2014 White Jeep Cherokee Trailhawk
3.2L
Leather Interior Group, Canyon Brown
Black Hood Decal
MFG build date 10/13
Black Keys all the way up on the stereo:
"Well my Next-Jeep, be nothin' like my Ex-Jeep"
Jeppy is offline
post #11 of 12 Old 01-19-2006, 02:07 PM
jcr23
check to make sure your front tires have equal air pressures
2000 XJ, mildly modded
jcr23 is offline
post #12 of 12 Old 01-19-2006, 02:24 PM
BIGNUTT
BIGNUTT's Avatar
my 242 sticks too, I was in 4wd, threw back into 2wd and drove around the neighbor hood 2 miles before it went out....suxs.
I have never tried backing up though.
CANCER AND LUEKEMIA SUCK
Proud to be a Christian
BIGNUTT is offline
Stuck in 4 wheel drive firewood XJ Cherokee Technical Forum 5 01-12-2010 02:31 AM
stuck in part-time 4-wheel drive Pit Partner XJ Cherokee Technical Forum 19 09-07-2008 12:23 PM
Xj Stuck In 4 Wheel Drive greenmudshark XJ Cherokee Technical Forum 5 07-15-2006 11:46 AM
Four wheel drive shifter stuck JayP XJ Cherokee Technical Forum 3 08-10-2004 10:22 PM
Stuck in 4 Wheel Drive? Scary insurrection151 XJ Cherokee Technical Forum 3 08-04-2004 05:28 PM
