Stretched TC case chain???? - JeepForum.com
post #1 of 4 Old 10-21-2005, 07:41 PM Thread Starter
mk20rockeye
Need some second opinions here! My 92 with the 242 TC in it is making a not to nice noise while driving. But the kicker is it only happens in 2WD. Also it only seems to happen about 30 MPH. It doesen't matter if i am coasting down a hill in neutral or taking off, whatever it may be about 30 MPH it makes this noise. I lock it into either 4WD part time or full time and the noise disappears except only during a decel from a speed above 30 MPH. I rotate the front shaft in @WD and I can hear some noise from the case while in $wd there is none. May this be the chain in there making noise from it being stretched and slapping the case?????
Your lack of planning does not constitute an emergency on my part
mk20rockeye is offline
post #2 of 4 Old 10-22-2005, 01:13 AM
DirtyCommanche
Unlikely. In 4wd with the rear on the ground, front up, how far can you rotate the front drive shaft until it stops? Shouldn't have much play. If there is, your chain might be messed.
But I don't see the chain in a 242 getting stretched unless you use part time on the road...
Do you have a vacuum disconnected axle?
DirtyCommanche is offline
post #3 of 4 Old 10-22-2005, 10:00 AM Thread Starter
mk20rockeye
with the np242. i do not believe it has the vaccum dissconnected axle, although i am not sure since i am new to this jeep thing and have had this about 3 weeks. as far as the play in the front drive shaft. i notice it most in 2wd, but has mimimal play. Although with the play it does have i can hear some slap noise coming from the transfer case
post #4 of 4 Old 10-22-2005, 05:51 PM
DirtyCommanche
Have you changed the fluid in it? It might be cooked (takes any type of ATF, but they recomend Dexon/Mercon III).
transfer case chain 88XJ_WI XJ Cherokee Technical Forum 1 09-11-2007 07:57 PM
transfer case chain? white94xj XJ Cherokee Technical Forum 3 08-30-2007 07:56 PM
T-Case chain swap 92 to 89 89heep XJ Cherokee Technical Forum 8 09-08-2006 05:42 PM
transfer case chain ilovjeep XJ Cherokee Technical Forum 11 11-03-2004 03:02 PM
Stretched chain = noise? thuper XJ Cherokee Technical Forum 7 04-21-2003 12:13 PM
