Strange Vibration upon acceleration, sometimes - JeepForum.com
post #1 of 11 Old 11-07-2012, 12:45 PM Thread Starter
zeaman
I recently put heavy duty rear leaf springs on my 01 xj, it lifted the rear way more than I thought and I had major driveshaft vibration. I added the shims and installed a transfer case lowering kit and it smoothed everything out. However, lately I have noticed when accelerating hard and steady, that there is a vibration/knocking under the center of the car, and I can feel it in my feet. It doesnt feel like the old vibration, or an exhaust rub, would this be a U joint, or is this a little vibration left over from the drive shaft?
zeaman is offline
post #2 of 11 Old 11-07-2012, 01:00 PM
cory4um
Re-torque all suspension bolts.
had a friend do a small lift. Never went back over the bolts after several hundred miles. Had a shake on accel.. I found the passenger u-bolts loose...
cory4um is offline
post #3 of 11 Old 11-07-2012, 01:39 PM Thread Starter
zeaman
Like the U bolts on the rear axle that hold the leafs down?
zeaman is offline
post #4 of 11 Old 11-07-2012, 02:01 PM
cory4um
Yup.
Its worth looking into.
cory4um is offline
post #5 of 11 Old 11-07-2012, 04:51 PM Thread Starter
zeaman
All of the bolts are tight, I noticed today the vibration is only noticeable under a lot of force. Could this be drive shaft u joints?
zeaman is offline
post #6 of 11 Old 11-07-2012, 06:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
...... noticed today the vibration is only noticeable under a lot of force. Could this be drive shaft u joints?
Very likely so. Any lift will often bring to light worn out u-joints. Vibes that are acceleration only, or deceleration only, are usually from worn u-joints. U-joints are cheap and easy, you probably could use some fresh ones.
CJ7-Tim is offline
post #7 of 11 Old 11-07-2012, 06:31 PM
joshrad
1997 XJ Cherokee
I've been thinking of doing my driveshaft u-joints too. Spicer 1310's are the correct ones for the driveshafts right?
Originally Posted by EJames1226 View Post
Once the members of jeepforum get drunk enough, anyone can be a lawyer.
Originally Posted by Spaz_Soldier
Wait! Does that mean XJs are Xtreme Jeeps?
joshrad is offline
post #8 of 11 Old 11-07-2012, 07:32 PM
CJ7-Tim
CJ7-Tim's Avatar
Yes.
CJ7-Tim is offline
post #9 of 11 Old 07-26-2015, 11:09 AM
saludalabs
Vibes during acceleration.
Have Vibes after 3 inch lift RC (new springs and leafs)
Tim Could I have bad U-Joints on my front drive shaft. The rear drive shaft had the U-Joints replace and balance at a machine shop. Still have the vibes. The shop wants to do a transfer case drop, since the vibes only happen during acceleration. Thanks David
saludalabs is offline
post #10 of 11 Old 07-26-2015, 11:18 AM
CJ7-Tim
CJ7-Tim's Avatar
Remove the front drive shaft and go for a test drive over the same roads/conditions that produces the vibes.
1997-2001 are more prone to vibes, and 00-01 have the low pinion D30 front axle which increases front driveshaft angles. IMO, a T-case drop should be considered a temporary solution, until you save up for an SYE.
CJ7-Tim is offline
post #11 of 11 Old 07-26-2015, 01:34 PM
saludalabs
Thanks Tim, I will try that. Also will start saving up for the SYE....
vibration
