strange tick-tick-tick? - JeepForum.com
post #1 of 7 Old 01-10-2007, 10:46 AM Thread Starter
9t3country
1993 XJ Cherokee
'93 4.0 is making some ticking (164,000 on it, use Mobil 1 10/30 ) - I'm assuming it is valve noise - what's strange is that it only does it when its cold, and the ticking starts only after it runs for a few minutes, and it only lasts for a couple minutes, then it sounds fine.
...so my question is is this something to be overly concerned with? thank you!
9t3country is offline
post #2 of 7 Old 01-10-2007, 10:48 AM
XJH-007
XJH-007's Avatar
Congrats! You've just come a member of the Cracked Manifold club!
Don't worry, most of us have been there.........
one word............... EBAY
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 7 Old 01-10-2007, 11:26 AM Thread Starter
9t3country
1993 XJ Cherokee
yep, looking at other posts that has to be the prob - thanks for the diagnosis... how soon should I get this replaced, & should I put a stock replacement on or a header (not really looking for increased performance - besides gas mileage -would the header make a big difference? also, who should I buy from (EBay scares me -got burned once :-( \
thanks again!
post #4 of 7 Old 01-10-2007, 11:26 AM
Meatroach
Meatroach's Avatar
1992 XJ Cherokee
I don't have a cracked mannifold and mine was doing that too...i ran some seafoam and it cleaned out all teh deposits and now no ticks!
XJ
[COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid
Meatroach is offline
post #5 of 7 Old 01-10-2007, 11:53 AM
kg4kzv
1995 XJ Cherokee
Mine just started clicking I have to fix some other things before I get to it. When I do I will get a good header maybe banks but haven't looked into it much so I can't recommend which one to get . I have A Toyota truck that has been known for cracking manifolds and it has had a header on it since I got it 6 years ago and no problems. I was told a long time ago that a leaking manifold will burn valves. But then someone said that a leaking manifold is not the cause for burning valves. I still think old school and would not put it off to long.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #6 of 7 Old 03-06-2008, 12:36 PM
treem06tj
what did you add that seafoam to? i need to get rid of this noise and if that helps i'm going to have to do it.
treem06tj is offline
post #7 of 7 Old 03-06-2008, 01:40 PM
jeepnphreak
1989 XJ Cherokee
I picked up a $6 can of Rislone at CKS and dumped er in the crank case. 30s later it stoped and its been quite for a month. Mine tick tick tick was just valve tap from a sticky lifter. Try that first before taring out the exause manifold.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
Strange Tick after shutdown Re4peR26 XJ Cherokee Technical Forum 0 08-27-2009 08:24 PM
Tick, tick, tick. What is it? trebay3 XJ Cherokee Technical Forum 2 07-26-2009 10:16 AM
XJ 4.0 tick Christoph XJ Cherokee Technical Forum 12 03-20-2009 12:53 AM
tick tick tick...I dont think its a problem? JeepNoma XJ Cherokee Technical Forum 12 02-11-2009 05:53 PM
Tick Tick Tick from engine - 4.0 danw77 XJ Cherokee Technical Forum 7 01-26-2008 04:07 PM
