Strange sounds front end in 4WD - JeepForum.com
post #1 of 8 Old 04-26-2010, 07:46 AM Thread Starter
prushinfox
This is for a 2000 Cherokee XJ.
When in 2WD and driving at any speed or turning, or in reverse, the drive train is quiet and smooth.
When in 4WD and driving at any speed, straight..or in reverse straight, the drive train is quiet and smooth.
When in 4WD and turning right of left on any surface, at normal 4WD operating speeds there is a strange sound like crunching, sometimes metallic. There is no play in the drive train nor slack in the steering linkages or box.
I am beginning to fear that the front diff. is hosed up. But I would think I would hear the sound all the time since it does turn (free wheel) in 2WD. Why wouldn't this occur when driving in a straight line?
I wanted to get your opinions before I embark on a tear down.
Thanks!
prushinfox is offline
post #2 of 8 Old 04-26-2010, 08:39 AM
Prosonic
Prosonic's Avatar
My first guess was going to be front u-joints, but you say there is no play in the drivetrain.
My next guess, would be spider gears, because of it only happening when turning. However, like you said, you would think they would act up even in 2WD.
I think you're going to have to open up the diff and see what's going on.
While your at it, check those u-joints one more time, you never know.
Mayhem in potentia
Prosonic is offline
post #3 of 8 Old 04-26-2010, 08:54 AM
trouttrooper
front axle U-joints are shot. replace immediately
trouttrooper is offline
post #4 of 8 Old 04-26-2010, 09:04 AM
lowicz96
1995 XJ Cherokee
If the ujoints are shot you will hear the noise when turning in 2wd as well but it would be as loud as in 4wd
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #5 of 8 Old 04-26-2010, 10:14 AM
Timo_90xj
Timo_90xj's Avatar
I'm gonna say u-joints. You might not feel anything wrong with them by hand, but after you replace they are quiet. I've seen u-joints so tightly stuck you could not turn then by hand when you removed the axle shafts. But believe me, they make a horrible noise while driving
Spider gears are another possibility, but I'd start with u-joints...
***Under construction***
Timo_90xj is online now
post #6 of 8 Old 04-27-2010, 06:50 AM Thread Starter
prushinfox
Ok folks, I'll check those U Joints thoroughly and then if there's nothing there, then I'll pop the front diff. After I finish building my deck
post #7 of 8 Old 04-27-2010, 07:06 AM
rc76
This may be a silly question... but are you trying 4wd on dry pavement?
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...)
99 Cherokee Sport- Stock and Staying that Way (Wife's DD)
rc76 is offline
post #8 of 8 Old 04-27-2010, 11:20 AM
Timo_90xj
Timo_90xj's Avatar
Even if he tries part time 4wd on dry pavement, it shouldn't make any "horrible" noises when turning if everything is fine. Nothing wrong in trying part time 4wd on dry pavement. It's the long-time use on dry pavement and higher speeds that will kill the drivetrain.
4wd , binding , front , noise
What sounds can a front hub bearing make if it's going out? firehawk XJ Cherokee Technical Forum 3 07-11-2008 08:43 PM
Front end sounds? McWood XJ Cherokee Technical Forum 4 03-07-2008 10:57 PM
Bad front end sounds 89XJ74 XJ Cherokee Technical Forum 4 03-06-2008 10:46 PM
Front End Sounds Rough!! Osteonis XJ Cherokee Technical Forum 5 05-16-2005 07:36 PM
Front End? Sounds. HailStorm XJ Cherokee Technical Forum 5 02-06-2005 09:09 PM
