Strange "popcorn" engine noise - JeepForum.com
post #1 of 11 Old 08-01-2012, 01:23 PM Thread Starter
portcityXJ
1995 XJ Cherokee
My jeep is a 95 XJ, 4.0 with just over 250k miles. I owned it for 6 1/2 years now and have taken good care of her. Recently i noticed i had a knock on start up and shut down (maybe 2 - 3 knocks each start up/shut down). After the jeep gets me to my destination and i put the trans in park, there is a metallic "popcorn" sound coming from the engine. its audible in the jeep, but loudest underneath. There does not seem to be any rhythm to the noise.
If i rev the engine, the noise goes away. The engine runs great, and i have not noticed the noise while running on the highway, only slightly at red lights, but mostly after a parked warmed engine.
Ive done a little research and most say its a flexplate bolt issue, however after watching some youtube videos, im not so sure. Ill see if i can get a video of it soon.
Any ideas? this is my way to work/school/life so i really need it as top notch as possible. Thanks.
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
post #2 of 11 Old 08-01-2012, 01:26 PM Thread Starter
portcityXJ
1995 XJ Cherokee
probably the closest i could find to give you an idea. except mine seems to vanish when the gas is pressed.
post #3 of 11 Old 08-01-2012, 03:31 PM Thread Starter
portcityXJ
1995 XJ Cherokee
my video. pay no attention to the engine chatter. turn the volume up to hear the clunking.
post #4 of 11 Old 08-01-2012, 07:17 PM Thread Starter
portcityXJ
1995 XJ Cherokee
bump for the night crew
post #5 of 11 Old 08-01-2012, 07:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
cruiser54 is offline
post #6 of 11 Old 08-02-2012, 01:09 PM
redjeep83
Might even be piston slap. Might have bad rings. Check out Jeepstrokers.com and check out the cheep Cherokee episodes of Trucks! There is an episode that they start it and it slaps for a few seconds and goes away as it warms up.
redjeep83 is offline
post #7 of 11 Old 11-26-2012, 12:46 PM
el_magico
1995 XJ Cherokee
Was there any resolution to this? My 95 XJ is doing the exact same thing. After a long trip and short rest, upon start up mine will knock like that until I rev it a little, possibly causing the flexplate to balance out by centrifugal force. Same thing a red lights from time to time, just a little on acceleration quiets it. but inside the Jeep it sounds like some one is trying to pound their way in from the floor board. At first I thought that it might be a rod knock but it doesn't knock all the time. I'll try to check it this week.
1995 XJ Sport 4.0L (Nothing special to list yet)
el_magico is offline
post #8 of 11 Old 11-26-2012, 02:33 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just do the flexplate bolts. can't hurt and might help.
What brand of oil filter are you using?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
post #9 of 11 Old 11-26-2012, 02:36 PM
el_magico
1995 XJ Cherokee
I really hope that's all it is! And I hope its not too late that the flex plate has cracked or something.
I use Amsoil filters.
post #10 of 11 Old 11-26-2012, 02:43 PM Thread Starter
portcityXJ
1995 XJ Cherokee
It ended up being a loose flexplate. I tightened the bolts up but that only lasted a few days. I ended up removing the bolts completely, one at a time, and reapplying thread lock and reinstalling them. That seems to have cured the noise. A dead giveaway is when you pull the cover, you see that the edges of the flex plate are shiny from contact.
post #11 of 11 Old 11-26-2012, 02:53 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See Post #5 for a link to a great write-up on doing the flexplate bolt repair.
Strange "miss/hesitation" charger_340 XJ Cherokee Technical Forum 14 04-08-2012 07:42 PM
"feathering" or "hissing" noise from engine? johnlocke XJ Cherokee Technical Forum 3 02-17-2011 12:42 AM
Strange "hollow" sound coming from flywheel area (I think) when starting/ shut off akxj01 XJ Cherokee Technical Forum 1 01-19-2009 06:05 PM
Strange Cherokee Problem ("no bus"?) ddem XJ Cherokee Technical Forum 3 01-21-2008 04:32 AM
Newbie with a question...strange "thunk" xjinga XJ Cherokee Technical Forum 1 07-26-2006 09:43 AM
