Strange noise from my 96 XJ - JeepForum.com
post #1 of 5 Old 01-12-2014, 09:05 PM Thread Starter
Lausten
Greetings, I am new to this forum and have read a number of threads, but nothing like the issue I am having.
I hear what sounds like the fan rubbing or something metallic rattling around the front end, engine compartment (hard to pen point), when I get to around 15-25 miles per hour and it continues. I do not hear it when at idle or when I increase the RPMs. It only happens when moving. I have checked and even removed the fan shroud and the electric fan, no change. It does not go away with time or speed. Any suggestions?
1996 Jeep Cherokee
4.0L
Manuel Transmisson
Thanks
JD
Lausten is offline
post #2 of 5 Old 01-13-2014, 08:47 AM
CCKen
CCKen's Avatar
1996 Jeep Cherokee
4.0L
Manuel Transmisson
Thanks
JD
Examine the crankshaft damper (harmonic balancer) for coming apart, and possibly rubbing on the timing chain cover.
CCKen is offline
post #3 of 5 Old 01-13-2014, 02:32 PM
uberxj92
1992 XJ Cherokee
X2
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 5 Old 01-14-2014, 06:40 AM Thread Starter
Lausten
Ok I will, would not the Harmonic Balancer make noise, when the
Engine is running and the RPMs are increased? I only hear it when moving above 15-25
MPH. Maybe it had to do with having a load on it.
I will check thanks.
-JD
Lausten is offline
post #5 of 5 Old 01-14-2014, 10:13 AM
psychoteen101
Check the heat shield on the catalytic converter as well.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
