Stock Shock Specs (lifted specs too) - JeepForum.com
post #1 of 1 Old 01-24-2007, 11:58 AM Thread Starter
79bigmack
79bigmack's Avatar
Looking for *Stock Shock Specs* for a late model (2000) Cherokee. i.e. the length of the shock (ex/ 6 inch, 8 inch, 10 inch, etc), and the brand/part number, and compression/extension numbers.
FYI - I checked the “Cherokee Stock Specs” thread and this info wasn’t in there, but surely someone has researched this before.
Also, if you have shock info on a lifted rig, please share…(ex/ I, Joe Jeeplover, have a 98 XJ with 3.5 inch lift and these shocks: xxxxxx).
I am trying to compile some info on “This lift = That Shock Length”.
Looking at lift kits online they give you the part numbers for the recommended shocks but they don’t tell you the compression / extension of that shock – and as you know that can vary from brand to brand even if they are the same length, and it can be your limiting (and damaging) factor when trying to get the most flex out of your set-up.
Thanks!
-Mack
Current Ride: '08 Grand Cherokee 4x4
Past trucks:
2000 Cherokee Sport 4x4 :(
2004 Discovery :(
2003 F-150 4x4
79bigmack is offline
Get your stock specs here! Country Jeep MJ Comanche Technical Forum 111 06-28-2015 11:08 AM
shock mount torque specs rockhopper XJ Cherokee Technical Forum 3 10-05-2013 07:49 PM
Bilstein Jeep Cherokee 4" Shock Specs trailwerks XJ Cherokee Technical Forum 4 07-29-2009 11:30 PM
upper front shock torque specs toates89 XJ Cherokee Technical Forum 2 06-30-2009 05:58 PM
Didn't see it in the stock specs section... wagnerdw XJ Cherokee Technical Forum 5 01-14-2004 04:18 PM
