Stock Shock list for lifts - JeepForum.com
post #1 of 7 Old 11-24-2010, 10:54 AM Thread Starter
rwlbjr
Here is a list I made when I was picking out shocks for my home brew lift. Putting it down on paper really helped me pick the right shocks for me so I hope it can help some one else.
I used air shocks front and rear, mostly because of cost and so I could level the back easily. But I listed regular shocks, coil overs, and air shocks. the air shocks only cost about $15 more / pair than cheep monroe shocks. I added part numbers so you can check with your local parts store.
Most of these will need some fab. Nothing too hard, mostly pressing out/in cross pins. the ford explorer and buick shocks already have pins but I can tell you that the buick shocks need to have the cross pins drilled out or ground to make them fit.
OE, F/R, Years, Length in", NAPA#, Notes
XJ F 91-01 13.2 - 21.2 37083 Stock
XJ R 84-01 12.8 - 20.0 37027 Stock
XJ R 84-01 12.8 - 20.0 58594 Stock, Coil Over
YJ F 87-95 14.5 - 24.4 37120 No Cross Pin
ZJ R 93-98 13.6 - 21.5 37082 No Pin
ZJ R 93-98 13.5 - 21.5 58619 No Pin, Coil Over
ZJ R 93-98 13.5 - 21.8 MA773 No Pin, Air Shock
F150 R 90-96 15.9 - 26.4 37039 No Pin
F150 R 90-96 15.8 - 26.4 58604 No Pin, Coil Over
F150 R 90-96 15.5 - 25.8 MA775 No Pin, Air Shock
F150 F 97-04 16.0 - 27.5 37134 No Pin, F150 rear, XJ front
F150 F 97-04 14.3 - 23.9 37132 No Pin, F150 rear, XJ front
F150 F 97-04 16.0 - 26.3 58629 No Pin, F150 rear, XJ front, Coil Over
F150 F 97-04 14.3 - 23.9 58628 No Pin, F150 rear, XJ front, Coil Over
F150 F 97-04 14.3 - 24.9 MA829 No Pin, F150 rear, XJ front, Air Shock
Explorer R 91-01 15.0 - 25.0 37035 Stock Fit
Explorer R 91-01 15.5 - 25.0 58617 Stock Fit, Coil Over
Explorer R 91-01 15.0 - 24.3 MA776 Stock Fit, Air Shock
Buick F 97-05 14.5 - 24.3 MA822 Drill/Grind Pin to Fit, Air Shock, Buick Rear / Jeep Front
Let me know if anyone has any questions, I just finished installing the buick and F150 Air shocks on my 96 XJ.
rwlbjr is offline
post #2 of 7 Old 01-02-2011, 09:22 AM Thread Starter
rwlbjr
Bump
rwlbjr is offline
post #3 of 7 Old 01-02-2011, 06:17 PM
ChEaPsK87
1987 XJ Cherokee
IMHO almost a good list. nice try though. one thing to remember is that most of the people on this forum are not mechanics. heck i bet there is a bunch that dont even know how to change their oil. so keeping this in mind your list looks like a bunch of random numbers and letters. maybe just simplify it some and what lift the shock would work best with. could even say if it hurts/helps up/down travel. otherwise it is decent info. just my .02
ChEaPsK87 is offline
post #4 of 7 Old 01-02-2011, 08:01 PM
EdgarS
Good post for the one of us that actually understand what all that info means
98muddyjeep: mine makes noise when shes parked.she used to purr like a kitten now its more like a 16 y/o asmatic cat in liver failure.
EdgarS is offline
post #5 of 7 Old 01-02-2011, 08:09 PM
Willy36
1990 XJ Cherokee
How the hell could that be confusing even for someone who doesn't know cars?
Willy36 is offline
post #6 of 7 Old 01-02-2011, 08:14 PM
Spencer43783
X2
They're called 'monkey charts' for a reason lol
Nice work OP!
1998 Cherokee Sport 4.0L-AW4-NP231-C8.25--Black, trim removed and chopped. 31" Goodyear Wrangler Duratracs. 3" lift coming soon.
1984 Grand Wagoneer--Sold. I'll miss the old girl.
Spencer43783 is offline
post #7 of 7 Old 01-03-2011, 08:49 AM Thread Starter
rwlbjr
The list looked better on paper, the spacing wasn't off... But if anyone has any questions, including how to read it, Let Me Know.
Stock front shocks are 13" compressed and 21" extended. so if you have 3" of lift and stock bump stops you need a shock that is 13" - 24" if you had added 2" to your bump stops than you could use a shock that is 15" - 24" And its always ok to go a little shorter on the compressed length and a little longer on the extended length. But never the other way...
Whatever you add to the length of your bump stops you can and to the stock compressed length, and you can add your lift to the extended length.
rwlbjr is offline
coil over , shock , shock absorber , shock length
need a full list of stock torque specs shortbussrydah XJ Cherokee Technical Forum 3 07-17-2009 11:03 AM
Oh NO!!!! another shock thread! Are RE's Monos best for thier lifts??? HumboldtXJ XJ Cherokee Technical Forum 8 02-28-2009 03:53 PM
stock wheels list steve89pioneer XJ Cherokee Technical Forum 2 12-02-2007 09:45 PM
The best stock to trail conversion list 98RedLtd XJ Cherokee Technical Forum 3 02-14-2006 05:13 PM
Stock '01 Jeep XJ, Looking to prepare her for light to medium wheeling... Parts list? amart565 XJ Cherokee Technical Forum 16 02-03-2004 12:35 AM
