Quantcast Stock compass help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Stock compass help
Old 09-10-2006, 02:00 AM   #1
aquaxbat
Stock compass help
I have a compass/temp guage above my rear view mirrow attached to the roof of my jeep (for those who don't look to the left too often, i own a 91 XJ Laredo) and i need to know if there is anyway to calibrate it and make it work to standards. can't find it in my chilton's, kind of vague on some the jeep models in there. i do know if i hold down the 2 buttons simultaneously (comp./temp and the standard/metric buttons) and 3 seconds later, the word "VAR" pops up and if i press the standard/metric button, it counts up from 1 to 15 (with each depression of the button) then starts over again. i know it does something with the calibration of the compass, because when i press the comp./temp button (appearently the on/off switch) for a second it turns off and when i turn it back on the direction has changed slightly (ie from E to SE or NE). the temp side says "OC" which i haven't a clue what it means (maybe a subliminal message to watch the OC tv series) ok lame joke, but anyways, does anyone know where i can find something online maybe to help fix or cal. it?? thanks!!
aquaxbat is offline   Reply With Quote
Old 09-10-2006, 09:11 AM   #2
88XJSport
1988 XJ Cherokee
Depending on what part of the country you live in, (washington), those numbers divide the country into 15 triangular pieces. I have chiltons, but dont waste your time this picture is not in there. Someone here will tell you what "number" your state is. As for the temperature OC means Open Circuit. I suspect something is wrong with your temp sensor. (it is smack dab ib the middle of the front bumper, but behind it. Thats about all the information i can give you. Good Luck.
88XJSport is offline   Reply With Quote
Old 09-10-2006, 12:51 PM   #3
jeeptorino68
1992 XJ Cherokee
ya does anyone have the number for oregon and idaho area? or are they differnet
thanks
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline   Reply With Quote
Old 09-10-2006, 02:30 PM   #4
PoPilot
The VAR is the variance and for your area it should be set to 4. After you set the compass variance - drive in a clockwise circle a few times to calibrate it.
The OC is open circuit - either your temp sensor is shot (RockAuto.com has them for 20 bucks) or its unplugged.
PoPilot is offline   Reply With Quote
Old 09-30-2006, 10:21 PM   #5
ChipsXJ
1993 XJ Cherokee
what would the setting for oklahoma be?
thanks
1993 Jeep Cherokee
4.0 Auto 4dr 4X4
RED JEEP MEMBER #253
ChipsXJ is offline   Reply With Quote
Old 09-30-2006, 10:42 PM   #6
88XJSport
1988 XJ Cherokee
thanks
Oklahoma is setting 6, except for the panhandle, which is setting 5. I would set it to six (or five) , then find a large parking lot, and as mentioned before, drive in a clockwise circle 3 times to calibrate it. Good Luck.
Old 09-30-2006, 10:46 PM   #7
stevenaa
What setting for Texas?
stevenaa is offline   Reply With Quote
Old 09-30-2006, 10:59 PM   #8
88XJSport
1988 XJ Cherokee
Six. Very western tip is five.
Old 10-01-2006, 02:36 AM   #9
madrabbitt
someone with a manual should scan that page and post it in here, and then get a mod to link this thread to the FAQ links.
i'd do it but i have no scanner.
i'll try to find the image online though
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 10-01-2006, 02:39 AM   #10
madrabbitt
Here you go
Old 12-04-2006, 04:12 PM   #11
sean87xj
Sorry to dig up an old thread but I've been trying to find this info for ages....
My temp. always reads "SC" (1990 model) or reads completely wrong, I'm gonna guess that means "shorted circuit" but I don't know for sure. Where is this part located on rockauto.com? I only see the coolant temp. sensor listed for my year, I'm assuming this is a seperate ambient temperature sensor....
Thanks a lot, this thing is driving me nuts!
sean87xj is offline   Reply With Quote
Old 12-04-2006, 05:15 PM   #12
madrabbitt
have you tried to calibrate it like this thread said?
Old 12-04-2006, 09:48 PM   #13
sean87xj
Yeah, the compass works fine -- just the temperature gauge is out of whack
Old 12-04-2006, 10:31 PM   #14
markmca82
The p/n of Rockauto.com is TX49. Take a look at more info for a pic and see if thats what you need. http://www.rockauto.com/catalog/x,carcode,1180011,parttype,7000 It shoiuld be the top one listed. Hope that helps!!
Mark
[B][FONT="Arial Black"][SIZE="2"]Black 1989 Limited 4.0L XJ
Rough Country 3" AAL
Pro Comp Xterain 31X10.50X15
Pro Comp 97 Series Rims
"Martinez" Edition
[/SIZE][/FONT][/B]
markmca82 is offline   Reply With Quote
Old 12-04-2006, 11:07 PM   #15
Backroads
good thread, a guy asked me other day if I calibrated my compass, I had no idea how to, know I do lol. Thanks for the info
Backroads is offline   Reply With Quote
Glock Forum
