Quantcast stock axles vs alloy axles ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > stock axles vs alloy axles ?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 02-20-2006, 06:51 PM   #1
NOS/86
are the alloy axles worth the money ? or should i save the money and just buy a few stock axles ?
the only axle i seem to have a problem with is the short side . 2 in 2 years i guess that anin't bad .
ps . i allways carry a spare for each side .
[SIZE=3]1990 PIONEER[/SIZE]
263,000 and still running strong !
FEAR ? YOU GOT TO CARE FIRST !
NOS/86 is offline   Reply With Quote
Old 02-20-2006, 06:53 PM   #2
conrasm
With that infrequent breakage, I'd stick with the stock axles if you don't want to put the money into the aftermarket axles.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Old 02-20-2006, 09:28 PM   #3
Blue XJ
1988 MJ Comanche
Is this for the 30 or the 8.8? If its for the 30, is it the shafts breaking or the ujoints? If it is the shafts, where are they breaking?
If its the ujoint, upgraded shafts won't help, the joint will still break and take out the ears on the shafts.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline   Reply With Quote
Old 02-20-2006, 10:00 PM   #4
NOS/86
IT'S FOR THE 30 . and yes the joints break taking out the ears on the axles ... so would better joints help ? say ctm's or something = ? but i guess with better joints ....i'd need better axles .
i've had cj's with 30's in the front not break the ears of the axles when the joint breaks .
Old 02-20-2006, 11:20 PM   #5
greenbeater
1968 FSJ Wagoneer
first thing is first i would upgrade to teh later model shafts.. (97 and up) as they have the bigger u joint.. (i found out the hard way by breaking both sides,,, (and im only on 31's)).. enjoy
clicky lefty for specs and here for cardomain
http://www.cardomain.com/ride/2212742/1
greenbeater is offline   Reply With Quote
Old 02-21-2006, 08:21 AM   #6
NOS/86
mine has the bigger joints . as far as i know all NON-DISK 30's have the big joints .
Old 02-21-2006, 09:06 AM   #7
spaghettixj
On a '90 xj you have the big joints only if you have ABS and not if you have a non disconnect axle.
Diego.
1990 2dr 4.0L engine - NP 242 - 6" Full Traction lift - 35X12.50 tires -
spaghettixj is offline   Reply With Quote
Old 02-21-2006, 09:22 AM   #8
IntrepidXJ
the short side is usually the side that breaks, as there isn;t as much deflection in the shaft because of the fact it is shorter.
as mentioned above, you only have the bigger joints if you have ABS in your 90.
anyways, as for alloys, I am running them after breaking a few joints/shafts........so far I have been unable to break them. I am running longfield joints (the old style)
Randy Langstraat
.: myXJ.net :.
IntrepidXJ is offline   Reply With Quote
Glock Forum
