Still Stumbling! Need Help! - JeepForum.com
post #1 of 14 Old 10-14-2008, 03:42 AM Thread Starter
kongpheng
Just last week I helped my brother with his 99 XJ.
His problem:
Hesitation / stumble / studder, whatever you want to call it. OBD code P0300which means -multiple cylinder misfire. This only happens from idle. While in Park and the pedal is pressed, it revs fine. When in drive and at a stop, it will hesitate / stumble / studder.... whatever you wanna call it.
So we changed out the spark plugs, wires, rotor cap and distributer rotor.
All the old parts we took out looked good except for the rotor cap and distributer rotor. they were Fudged UP! distributer rotor was messed up and looked like the culprit.
The Jeep started up perfectly with no problem. *** Jeep started fine before we did tune up too! ***
This week, it happened again. we took everything out. everything looks like how it did when we bought them from the LPS. We're stumped.
MY next thought would be....... the whole distributer system.
What do you think? Any advice would be great. Thanks.
2001 Cherokee XJ Sport 4.0L
3" Rough Country Lift w/ Daystar 1.25" TC Drop Kit
Flowmaster Delta 40 Series
K&N Drop in Air Filter & Procomp 10" E-Fan
AirRaid TB spacer w/ 62mm Bored TB
BFG All-Terrain K.O. on Black ProComp 87's
kongpheng is offline
post #2 of 14 Old 10-14-2008, 11:58 AM
Rtbeebe
1997 XJ Cherokee
Take off the distributer cap and see if there is any play in the distributer. If there is thats your problem. The firing is out of time and throwing a misfire code. If thats not it then check your coil pack. Upon giving gas the coil might be heating up and breaking down. Double check to make sure you got all the plug wires seated securely to the cap and plugs too.
97 Cherokee sport 4WD w/ 4.0
Rtbeebe is offline
post #3 of 14 Old 10-14-2008, 12:23 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What brand and type of spark plugs. Most Cherokees do not run well on SplitFire type or Platinum type plugs. They seem to run best on plain old Champion Truck Plugs.
Test the Throttle Position Sensor. Consider replacing the Coolant Temp Sensor on the thermostat housing.
CJ7-Tim is offline
post #4 of 14 Old 10-14-2008, 01:56 PM Thread Starter
kongpheng
We installed the Champion Truck Plugs.
post #5 of 14 Old 10-14-2008, 02:15 PM
carmannj
X2 I had the same problem. It is a good thing to check when a XJ starts running like that. Alot of the computer's timing and fuel mapping is based on it.
2007 Rubicon Unlimited
2005 TJ Rubicon
carmannj is offline
post #6 of 14 Old 10-14-2008, 05:00 PM Thread Starter
kongpheng
Good thinking! I completely forgot about the CPS. My brothers XJ could be suffering from the CPS. I'll jump on this one and get back.
post #7 of 14 Old 10-14-2008, 08:10 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Not the cps, the tps= throttle position sensor.
xjfever is offline
post #8 of 14 Old 10-15-2008, 07:08 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Another vote for throttle position sensor testing....
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #9 of 14 Old 10-15-2008, 08:40 AM
ernesttbass35
stuttering jeep
Take the computer out of that Jeep, pull one of the torx head screws at a time, cut it in half (they are 1/2 inch long), and replace it then do the other one. These screws are too long and iterfere with the operations of the main brain over time. I haven't had a problem since, and it's been 6 mos. or more. I had previously replaced everything in the electrical system before this, and things would straighten out for a week or two... now it is all set!!!
ernesttbass35 is offline
post #10 of 14 Old 10-18-2008, 11:58 AM Thread Starter
kongpheng
Alright, CPS didnt work! Its been 4 days since we replaced it. P.O.S.!! Anyway, TPS will be the next thing to be replaced.
post #11 of 14 Old 10-18-2008, 01:52 PM
mctwin2kman
I had a mild stumble I was getting. Did a full tune-up and found my Coolant Temp Sensor bad as well, replaced and still had it but not as bad. Replaced the O2 today and all is well now. So check you Temp Sensors, air and coolant, and O2.
mctwin2kman is offline
post #12 of 14 Old 11-03-2008, 03:12 PM Thread Starter
kongpheng
Thanks for the reply. Im not so sure the sensors have anything to do with My topic. My brother and I are just so friggin confused.
BTW, TPS has not been changed. Dont want to spend anymore money on this thing. I need a 100% suggestion.
post #13 of 14 Old 11-03-2008, 03:16 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I still say it's the TPS, which would have been the first thing that I replaced, but if you choose to do it last, then that's your call.
xjfever is offline
post #14 of 14 Old 11-03-2008, 06:09 PM
tjwalker
tjwalker's Avatar
I think you need a change in strategy. I would recommend getting a good service manual and start "testing" parts. It is a much cheaper and more efficient way of isolating root cause than throwing parts at the problem. And in the process, you learn a tremendous amount about your vehicle. The TPS can be easily checked with a digital meter.
tjwalker is offline
4.0 stumbling badly!! wahoo50 XJ Cherokee Technical Forum 11 01-31-2009 06:16 AM
stumbling? over bumps callingclair XJ Cherokee Technical Forum 10 09-16-2007 06:32 PM
stumbling now and then?? shierkahn XJ Cherokee Technical Forum 13 12-02-2006 12:59 PM
stumbling/missfire 88wagon XJ Cherokee Technical Forum 4 11-02-2006 06:16 AM
stumbling while driving jeepcherokeev6 XJ Cherokee Technical Forum 3 04-15-2002 09:08 AM
