still an oil leak HELP!!!!!! - JeepForum.com
post #1 of 14 Old 06-23-2013, 05:35 PM Thread Starter
87xjmav
ok im new to this site but here it goes. I have an 1987 jeep Cherokee that is still leaking oil pretty bad. #1 replaced oil pan gasket #2 replaced rear main seal #3 replaced valve cover gasket. im completely stumped guys is there anything else I can do before I run it off a cliff
87xjmav is offline
post #2 of 14 Old 06-23-2013, 06:29 PM
AvsXJ99
Can you tell at all where the leak is coming from?
AvsXJ99 is offline
post #3 of 14 Old 06-23-2013, 06:34 PM
blackolive99
Degrease it and then run it. Fresh leaks will show up fast.
blackolive99 is offline
post #4 of 14 Old 06-23-2013, 06:48 PM Thread Starter
87xjmav
its comin down on top of the starter then running into the bell housing onto the exhaust. I kill mosquitos going down the road lol
87xjmav is offline
post #5 of 14 Old 06-23-2013, 07:05 PM
rjbruzan
Oil filter adapter?
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #6 of 14 Old 06-23-2013, 08:21 PM
blackolive99
X2 on the adapter. I fixed mine after I did my motor mounts. It poured!
post #7 of 14 Old 06-23-2013, 10:17 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's all you need to know:
I'd be looking up ABOVE first, and VERIFYING the source of the oil leak YOURSELF.
Everybody, who doesn't own or have to pay for or perform your vehicle repairs, loves to poke their noggin UNDER the Jeep and come out bearing the false bad news that your RMS is leaking.
Many mechanics, friends, people on Jeep forums who can’t see your Jeep from where they’re at, and good old Uncle Bob seem to enjoy telling you it’s the rear main seal. Has a catastrophic ring to it, doesn’t it?
A simple leak at the back of the valve cover or other source could produce the same symptoms. You don’t need to be a mechanic to figure this out. If you have good eyesight and a dim flashlight, you’re good to go on your own. Don't jump on the RMS/oil pan gasket bandwagon right off the bat.
Almost any oil leak on your 4.0 is gonna drip from the RMS area for two simple reasons.
First off, the engine sits nose-up and any oil will run back to the RMS area. Secondly, the RMS area is also the lowest point on the engine. Simple physics and the old plumber's adage apply here. "***** flows downhill".
Valve cover gasket, oil pressure sending unit, oil filter adapter seals and distributor gasket, in that order, have to be eliminated as possibilities first.
Revised 02-26-2013
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #8 of 14 Old 06-24-2013, 07:58 AM
Pats94
Degrease with cleaner. Take one bottle of baby powder douse the side of the motor. Look for brown powder after running. There is your leak.... easy plus it makes it smell baby fresh...
Why does everybody make finding a leak so tough?
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #9 of 14 Old 06-24-2013, 01:43 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You got me. That's why I posted the write-up above. So many leaks are misdiagnosed by people with half-assed answers, it makes you wanna puke.
post #10 of 14 Old 06-24-2013, 04:01 PM
Pats94
I know what you mean...
I'm still trying to wrap my head around last weeks "cheap" fix by welding ball joints in....
Pats94 is offline
post #11 of 14 Old 06-25-2013, 06:03 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Thought you might like this:
Chipmaker says:
“Way more problems get solved by using your five senses under your hood rather than your ten fingers on a keyboard”
post #12 of 14 Old 06-25-2013, 07:14 AM
Pats94
Chipmaker says:
Lol. Novel concept! A lot like when engineers would come out to the track. Huh so that's why that design sucks.... you could talk until blue but a live "catastrophic failure of containment" was priceless!
Pats94 is offline
post #13 of 14 Old 06-25-2013, 10:15 AM
xj-jake
Mine ended up being the distributer gastket after i replaced about everything else under the hood
99 XJ 6.5" IRO Long Arm on 17" Pro Comp 7086 wheels w 33" Tires
xj-jake is offline
post #14 of 14 Old 06-25-2013, 02:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep. And a systematic method of diagnosis would have been easier and cheaper. all is not lost though as the other gaskets/seals are now new.
