Quantcast Still no heat, and I've had it. - Page 5 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Still no heat, and I've had it.
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 12-17-2008, 11:01 AM   #61
kadetklapp
2008 MK Patriot
You don't have to pull the passenger airbag?
**2008 Jeep Patriot Limited 4x4**
60k, *Absolute Rubish*
Former-
2004 Jeep Grand Cherokee Special Edition 4x4 V8.
1999 Jeep Cherokee SE
kadetklapp is offline   Reply With Quote
Old 12-17-2008, 07:53 PM   #62
FrankZ
1997 XJ Cherokee
Yes, the drivers side doesn't come into play at all.
Spec's
FrankZ is online now   Reply With Quote
Old 01-12-2010, 12:40 PM   #63
lollygagger8
So whatever happened with this?
89 YJ w/ 4.0L and AX-15 from a '97, NP231, 4" Skyjacker Leafs, 2" body lift, 35" MTZ's, Skyjacker Nitros, 8.8 rear, Dana 35 front, 4.10's.
96 Cherokee Sport w/ 4.0L, AW4, NP231, 4" Lift, 31" BFG AT's
lollygagger8 is offline   Reply With Quote
Old 01-12-2010, 01:31 PM   #64
Kevin108
Back from the dead @ 167k
Kevin108's Avatar
Mine's about the same as the OPs. Do you get decent heat with the switch set to recirculate?
It took me a while, but I finally figured it out: catastrophic failure and
the subsequent repairs is the Jeep thing they're always talking about.
Kevin108.com | My 2000 XJ Build | Hampton Roads Jeep Club
How to reindex the camshaft position sensor on an 00-01 XJ
Tips on trimming 97+ XJ bumper end caps and lower facia
Kevin108 is offline   Reply With Quote
Old 01-13-2010, 01:04 PM   #65
lollygagger8
I only get warm-ish heat. It seems like the higher the fan blows, the worse the heat gets?
Plenty of Coolant
New T-Stat
New Heater Valve
Old 01-13-2010, 01:12 PM   #66
jsmiddleton4
1997 XJ Cherokee
FrankZ,
Can you expand on the steps you took a bit? I'm getting ready to do swap of heater box due to a/c evap leaking. I've been looking that the thread that completely drops the dash, steering wheel, etc. You picture and posts indicate that is not necessary. Which is great. But what is necessary?
jsmiddleton4 is offline   Reply With Quote
Old 01-13-2010, 01:55 PM   #67
FletchXJ
I know this doesn't "solve" the problem, but if it was me I would want immediate satisfaction, even if it was just temporary. I saw a thread on here about some cheap plug in heaters that seemed to be pretty decent at Harbor Freight for between $5-30. Maybe something to keep you from freezing, .
FletchXJ is offline   Reply With Quote
Old 02-12-2010, 01:46 AM   #68
Yozho
If you're using the heater control valve, make sure the valve itself is opening when you push the climate control to the 'HEAT' setting. Also make sure both hoses leading from the core to the thermostat and water pump are hot.
Yozho is offline   Reply With Quote
Glock Forum
