Quantcast Still no heat, and I've had it. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Still no heat, and I've had it.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 12-04-2008, 09:34 PM   #16
car5car
Flush heater core with garden hose both ways in turns. Maybe there is a way to flush it with some coolant system flushing fluid. Does your Jeep have heater valve? If it does maybe it doesn't work. Just sell me your Jeep and stop worrying about heater problem, I'll take care of it!
97 4X4 M.Tr. about 2 inches lift
car5car is offline   Reply With Quote
Old 12-04-2008, 09:46 PM   #17
turpehar
Nice Doggy
turpehar's Avatar
1977 CJ5
Heater core needs replaced, plus your blend door issue
I've been married so long I don't bother looking
both ways before crossing the road.
Originally Posted by Cause View Post
So what I have has a name; Beachin Intolerant
Originally Posted by Roadyy View Post
His stuff still gives me a chubby every time I hold it in my hand
(Trial + error)*Upgrades) - $² = (mac-n-cheese/hot dogs)+experience
turpehar is online now   Reply With Quote
Old 12-05-2008, 07:12 AM   #18
kadetklapp
2008 MK Patriot
But......what about
The heater hoses were plenty hot, both in and outflow
**2008 Jeep Patriot Limited 4x4**
60k, *Absolute Rubish*
Former-
2004 Jeep Grand Cherokee Special Edition 4x4 V8.
1999 Jeep Cherokee SE
kadetklapp is offline   Reply With Quote
Old 12-05-2008, 07:30 AM   #19
FrankZ
1997 XJ Cherokee
Did you read my reply?
Partially clogged means that it is not 100% clogged. Some coolant is getting through, hence the small amount of heat. Heat is conducted easily by water/coolant so even without any flow through the core both hoses will be hot.
Spec's
FrankZ is offline   Reply With Quote
Old 12-05-2008, 07:37 AM   #20
kadetklapp
2008 MK Patriot
There is steady flow thru the core which my mechanic is telling me means that there is adequate flow for heat.
You may very well be right, we'll try the blend door and see.
Forgot to add, I did get some Prestone coolant system flush. I poured one bottle in the resevoir tank since it's filthy, and this weekend I'll take the lower hose off and drain some and add the next bottle to the system itself. Figure I'll run it for a few days and then try "flushing" it with the garden hose again, provided the garden hose isn't frozen solid...
Former-
Old 12-05-2008, 08:25 AM   #21
Rtbeebe
1997 XJ Cherokee
I had a broken blend door and my air would only come out the defroster vents. The blend door you have broken is probably the one that blends cold outside air with warm air that flows past the core. Really you need to just bite the bullet and remove the heater box. That is also the only way you will be able to replace the blend door. Some blend doors are attached to the heater box cover and some are attached to the box. I've had to do this twice, once for a leaking heater core, which I replaced the cover and the broken blend door, and once for a leaking AC evaporator core. Not fun and took a full day but I have heat!!!!! I bought a haynes manual from AZ and thats all I needed to do the job. Be patient and don't drink beer while taering it apart. Once you get the heater box out and see what parts need to be replaced you can visit a junkyard or visit a dealer based on your budget. Also take into account you will have to open up your AC system to remove the heater box so be prepared to get you AC system refilled, prefereably by a professional.
Best advice and good luck.
97 Cherokee sport 4WD w/ 4.0
Rtbeebe is offline   Reply With Quote
Old 12-05-2008, 08:33 AM   #22
kadetklapp
2008 MK Patriot
The heater treater kit prevents you from having to tear the dash apart, as you cut into the box.
I will sell this thing at a loss before I remove the dash.
Former-
Old 12-05-2008, 12:31 PM   #23
turpehar
Nice Doggy
turpehar's Avatar
1977 CJ5
That goo that lines the inside of the tubing in the heater core acts like an insulator. It's not letting any heat radiate out of the core, but yet hot water continues to flow through from the "in" side to the "out" side. No matter what position the blend door is in, there should be air flowing somewhere.
Old 12-05-2008, 02:47 PM   #24
kadetklapp
2008 MK Patriot
I'm getting air, cold air, out of the vents. THe blend door is open on the cold side only, and will not go the other direction for warm.
Former-
Old 12-05-2008, 03:58 PM   #25
88XJSport
1988 XJ Cherokee
But you said this in your first post...
Blend door motor works and turns properly, as it should.
88XJSport is offline   Reply With Quote
Old 12-05-2008, 04:06 PM   #26
kadetklapp
2008 MK Patriot
Yup, the motor itself works fine, but when the motor is up under the dash screwed in place, it literally bends out of it's bracket because it's stressed so bad. The axle is cracked all the way around. In place, the motor will not turn. Holding it in your hand, it turns just fine.
Former-
Old 12-05-2008, 06:03 PM   #27
AZ Jeff
So are you going to do the heater treater repair, or have you given up on fixing it?
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 12-05-2008, 06:37 PM   #28
cherokeekidd
C'Mon, Ill take a cheap jeep to tear apart the dash and make the heat work. In my opinion, get the jeep in a warm shop, grab a 12 pack, a pack of smokes(if you smoke), and a toolbox. Go to town and get the dash apart, fix it, and save the trouble of selling, transferring, loosing a good jeep and gain the pride of fixing a B!tch of a problem. Id love to come help if your in Columbus, Ohio area anytime....
cherokeekidd is offline   Reply With Quote
Old 12-05-2008, 08:28 PM   #29
kadetklapp
2008 MK Patriot
Well, we are sure the blend door is stuck, so I'm probably going to go ahead and fix it since it needs it anyway. If I go thru that and it still isn't heating, then its gone.
I simply can't afford to evacuate, remove, and reinstall the AC system.
Former-
Old 12-07-2008, 10:06 AM   #30
kadetklapp
2008 MK Patriot
Your post is inspiring. We will see. I just got a line on a sweet 97 XJ Sport right down the street. Only $2900 and it's cherry.
Former-
Glock Forum
