Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Cherokee & Comanche Forum Group > Cherokee Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 03-29-2006, 06:08 PM   #1
xjrrrdx
Send a message via AIM to xjrrrdx
Still getting warm
Well after replacing my tstat with a 195* tstat, a CSF 3-row rad, new water pump i was driving normal, today was a warm day like yesterday but today just driving and sitting at lights I noticed that my temp would climb to about 220*-230* then the electric would kick on and keep it there but not really lower the temp until I got up to speed.. but i guess i am kind of stumped as why it would still get so hot after replacing my whole cooling system. Any ideas??
Oh yeah I forgot, my cat is pretty clogged, tomorrow im replacing that as well. but i doubt that has anything to do with it.
96 XJ 159k
RE ZJ 3.5" coils with 1.75" spacer, DPG 5" springs, JKS 1" shackle/ Black Steelies 4" BS/ 34" Trxus MT / RK 3-link LA / Rock Monitor Front Bumper / RE XD Trackbar w/ mount / C-Rok Rear Bumper / Aussie Front Locker / AJs Sliders, RE H&T
www.rocklizardfabrications.com
xjrrrdx is offline   Reply With Quote
Old 03-29-2006, 06:59 PM   #2
noliepolie
possibly a blown head gasket.
96 Jeep Cherokee Sport 140000 miles. Too many mods to list!!!
noliepolie is offline   Reply With Quote
Old 03-29-2006, 07:07 PM   #3
cmotsvt
Is your mech. fan working? Is your fan shroud in place? Do you have any airflow obstructions?
cmotsvt is offline   Reply With Quote
Old 03-29-2006, 08:04 PM   #4
xjrrrdx
no, the shroud broke and have not had a chance to get one yet
96 XJ 159k
Old 03-29-2006, 08:06 PM   #5
lockinup
Air bubble in the upper radiator hose?
lockinup is offline   Reply With Quote
Old 03-29-2006, 08:06 PM   #6
mylt1
get a new shroud and make sure the mec fan is working right and make sure the system has no air in it.
mylt1 is offline   Reply With Quote
Old 03-29-2006, 08:23 PM   #7
Atl XJ
That, and I'm leaning towards the fan clutch being worn and needing replacing.
Atl XJ is offline   Reply With Quote
Old 03-29-2006, 08:27 PM   #8
stevenaa
Might also be an inaccurate Temp. gauge. My 91 reads 20 degrees to high. I plumbed in gauge and mounted so it hangs down to the right of the steering wheel next to the console.
stevenaa is offline   Reply With Quote
Old 03-30-2006, 04:20 AM   #9
xjrrrdx
How long does doing a fan clutch take, and will i need to take anything major out, i dont feel like taking the rad back out haha.
96 XJ 159k
Old 03-30-2006, 09:19 AM   #10
mylt1
4 bolts and a little wiggling and it should come right out.
Old 03-30-2006, 04:05 PM   #11
xjrrrdx
Last thing, how do i make sure there is no air in my system? I thought the open system you dont have to worry about burping it or anything. And what are signs of a bad fan clutch, i dont really want to replace it unless it is going or has gone.
96 XJ 159k
Old 03-30-2006, 04:30 PM   #12
krAscH n' BurN
i recently had to replace my water pump thermostat and housing also, I bought this 8 dollar flush n' fill kit from prestone (at any auto store) that helps refill coolant and get out any depsoites in your lines that would resist flow.....all you do is splice it into your heater line that runs from your thermo housing to your heater core (hose next to your valve cover) and instruction are with it......
p.s bad colant or low colant is a possibilty
95' xj white, 5-sp, dana 30-35, 4 1/2"RC lift, 15x8 black rock krawlers, 31" BFG AT ko, minor trimmed and coated, intake, T-B spacer, chip, flowmaster(no cat), Banks Headers, 2.5" pipe, H4 conversion, ...alpine head, Alpine typeR 5 1/4,
krAscH n' BurN is offline   Reply With Quote
Old 03-30-2006, 06:45 PM   #13
mylt1
on an open system you still need to run the jeep till its up to temp and make sure the rad is full. you can still get ain in the system. also you want to make sure when your doing this that your heat is on that way you fill the heater core and heater hoses.
Old 03-30-2006, 08:15 PM   #14
lma1973
What is the normal temp anyway? On my 1987 4.0 it seems like if i idle forever the temp gets up to about 210.
lma1973 is offline   Reply With Quote
Old 03-30-2006, 11:40 PM   #15
Kuasimodem
Send a message via MSN to Kuasimodem
We-e-e-l-l-l-l, a partially clogged cat will create too much backpressure and will cause the engine to run hotter than normal. Voice of experience here, I had an 86 Mustang with a V-6 that started running very hot, then it started running really bad, no power. After removing what was left of the cat's internals, the overheat and power loss problems disappeared.
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline   Reply With Quote
4.0 warm up brandontrek Cherokee Technical Forum 6 09-06-2009 04:51 PM
AC and WARM air Chivo140 Cherokee Technical Forum 6 07-21-2009 11:24 AM
warm just warm sofiYJ Cherokee Technical Forum 4 01-26-2009 04:39 AM
Getting Warm xjrrrdx Cherokee Technical Forum 12 02-07-2007 10:43 AM
Warm up pretzelperson Cherokee Technical Forum 1 05-02-2005 11:06 AM
The time now is 11:35 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
